My new Pro Alloy RS 500 style Intercooler!
Picked my car up from Wayne on Saturday with this bad boy installed…
I have the first Escort Cosworth RS500 style intercooler from Pro Alloy,
also Wayne believes it’s the first time a 50mm thick core intercooler has
been installed in and Escort Cosworth!
OK, not the first but most RS500 style intercoolers tend to be 40mm.
I have to say that I am impressed so far,
The drive home showed, lower air charge temps, not all that surprising I suppose!
The car felt better, more responsive, pulled harder & stronger all the to the rev limiter!
I think this is due to the physical size & good airflow compared to the smaller more restrictive standard intercooler.
Also the build quality is excellent and it looks a beast!
Also here is a picture of my new Pro Alloy swirl pot.
To follow will be a nice oil breather & possibly a new alloy header tank too.
Again big thanks to Wayne at www.proalloy.co.uk top bloke top poducts!
Originally Posted by Turbo lag
was it hard to fit Gavin?
Dave.
Dave.
I think it goes in from underneath the car, so no need to take the bumper off.
also its designed to use your standard hose arrangement, so no need to buy custom made ones.
Gav
www.proalloy.co.uk
Originally Posted by Ian@Racetek
50mm cores have been fitted in Escorts for years. Mine since 1998 !!
Top looking stuff though!
Gav
Gav
No probs mate .... I am sure Pro Alloy will very soon become the market leader in road car applications down to the superb quality of finish etc. Fair play to Wayne and co for his hard work.
Just spent an arm and a leg at national day on the pro alloy stand!!
bought a header tank with sight glass, alloy rad and pre rad!!!!!
The stuff is top quality though!!
I fitted one to the saff the weekend(PRO ALLOY) just bolted straight up no fooking about.
As long as you use the rubber mounts and sleeves bolts off the water rad you can`t go wrong
finns 6103130 x 4 rubber bush Ł0.41 p
1610196 X 2 sleeves Ł0.45 p
6153053 x 2 bolts Ł 0.41p
well pleased with it car pick`s up a lot quicker and smoother than before
590 BHP/Ton
sorted off to Ford tommorrow
thanks doo for the part numbers..
www.proalloy.co.uk
Gav
would these bolts be ok for the Ecort Cos to mount it in front of the radiator?
Dave.
Dave.
Fit`s perfect I i mean looks like factory fitted don`t rub anywhere 100% correct just buy these items for a few quid and your sorted
Wazzer you have PM.
590 BHP/Ton
Originally Posted by lamb chops
I have one too and as above very very nice Just need the rest of the stuff to match
www.proalloy.co.uk
Thanks for that Nath,
little embarrassed last night, when I booted it out of the roundabout with Mike behind me only to find I was in LOW boost!!!!!
www.proalloy.co.uk
