Tips for removing snapped turbo bolts??
Old 24-11-2006, 06:02 PM
NathR
NathR's Avatar
Default Tips for removing snapped turbo bolts??
As title??
Old 24-11-2006, 06:07 PM
radiant red
radiant red's Avatar
gas axe
Old 24-11-2006, 06:26 PM
pete mcrash
saff is working!!!...atm
pete mcrash's Avatar
turbo to what?????
Old 24-11-2006, 06:30 PM
rapidcossie
rapidcossie's Avatar
drill out and re tap hole?
Old 24-11-2006, 06:38 PM
Kev.H
Kev.H's Avatar
you havent
drill it mate or weld on a nut if you have a welder
feel gutted for ya i know how it feels to break a nut
Old 24-11-2006, 06:41 PM
NathR
NathR's Avatar
Have welded a nut TWICE to one, and it snapped off both times. The other one is flush with the flange and I've spent hours and only half drilled it out!
Turbo to manifold btw.
Old 24-11-2006, 06:43 PM
Kev.H
Kev.H's Avatar
you broke 2
I laugh\cry cos I know your frustration
drill n tap let me know if you do this on or off the car
hope you get it sorted dude if I can help let me know even if its talking you out of gas axing the fucking car
Old 24-11-2006, 06:54 PM
SteveB
SteveB's Avatar
Very common on the FRS..... drill it out and use a nut and bolt... it isn't a 2 minute job either drilling them out
If its taken you over an hour you are using shit drill bits, start with summit like a 5mm bit and regularly sharpen it then work up the drill size once you are thru until you can get the right size bolt thru, I'd expect 15 min max tbh on each bolt
Old 24-11-2006, 06:57 PM
Escos Jam
Escos Jam's Avatar
depend on the break pal. double nut it, or use easy outs !
Old 24-11-2006, 07:15 PM
glancy2081
glancy2081's Avatar
drill it out mate use tungsten tipped drills start with 3.3 mm and work up from there uses fastest speed on drill
Kev.H
Kev.H's Avatar
For Sale: Focus RS, Non Runner, Lady Owner, buyer collects any sensible offer
ps this is not a for sale add
Old 24-11-2006, 07:17 PM
Escos Jam
Escos Jam's Avatar
Wats that gotta do with it mate
Old 24-11-2006, 09:40 PM
Boost Junky
Boost Junky's Avatar
Had the same thing on mine Nath... Took about an hour on each bolt Drilled em out, but had to borrow some decent drill bits off a friend as i fucked mine up good and proper in a matter of minutes
Good luck with it
Old 24-11-2006, 10:28 PM
CabbyRS
CabbyRS's Avatar
Yeah i did the same thin on me Escort just trying to nip em up snapped one and continued to nip up another 3
Got em drilled out as they were right in the hole so to speak, or u could get em spark erroded if u can find someone
Good luck
Old 25-11-2006, 07:54 AM
COCHYN
COCHYN's Avatar
@ NathR
You didn't by any chance try to remove these bolts while the engine was still hot did ya? As the bolts expand and proper weld themselves in the thread. I'd know, as I snapped 2 bolts on the flange when I fitted my manifold....oops!
Went through 2 very expensive drill bits to get them out, then went and bought proper, non-ford bolts from a iron works place for £3.50, with proper bolt type tops, not the stupid allen key jobbies!
If you need a set, let me know, much easier to tighten these bolts down, as their the normal kind...
Old 25-11-2006, 12:09 PM
NathR
NathR's Avatar
Update, drilled one hole (got some cobalt bits but still took ages) but then whilst tapping snapped the fooking tap holder.
The other one has 10mm of thread sticking out, so I keep welding nuts on, and occasionally snapping them off!!! Bastard turns 3/4 of a turn both ways but can't get the cunt out, really fucked off tbh.
Old 25-11-2006, 12:17 PM
trotty
trotty's Avatar
you can get stud extractors,usually from a good engineer suppliers.
its like a slot drill (milling tool) but what happens is, as you drive the extractor into the end of the stud,it has a left hand flute on the outside which pulls the stud out. you just put them in a power drill.
Old 25-11-2006, 12:33 PM
NathR
NathR's Avatar
Got the mentioned stud out, but the thread in the hole is a bit fooked. So now, I've just gotta tap two holes, but thats not proving especially easy!
Old 25-11-2006, 03:24 PM
Boost Junky
I broke a tap when trying to re-do mine Nath! What a twat that was... keep at it mate you`ll get there in the end!! I spent the best part of 2 days sorting mine out when fitting my manifold!
Old 25-11-2006, 05:06 PM
NathR
NathR's Avatar
Cheers for the vote of confidence Barry, will keep at it, just run out of spare time for a while now!
Matt Baxter
16-09-2015 08:30 PM
JoeyBoyden
14
15-08-2015 09:51 PM
track.focus'd
12-08-2015 05:53 PM
Bosch
04-08-2015 05:14 PM
MARKYMARKONE
02-08-2015 09:33 PM
Quick Reply: Tips for removing snapped turbo bolts??
