weird one.....car wont start
Old 23-11-2006, 07:07 AM
gingeRS
gingeRS's Avatar
Default weird one.....car wont start
thought i would post up here while i had a quiet 5 mins at work, but will be calling stu for some advice when he gets in to work.
last night:
got my new closed loop chip, opened up the ecu, did the mods to the baby board, (only a trim of the pcb, no electrical changes) put on the new chip, and plugged the ecu back in.
went to start the car and nothing (engine turned, wouldnt fire up), went inside swapped the old chip back, refitted it and found that same, car wouldnt start.
this morning
refitted the closed loop chip, plugged in the ecu, and tried again, nothing. upon closer inspection i heard a ticking coming from under the bonnet, when the ignition is on. invetsagated and it was coming from the distributer, unplugged the phase sensor, still ticked, when i went to unplug the coil lead ( ) i got a big shock up my thumb.
so this may be the fault.
any suggestions what could be causing the distributer to be arcing out? and stopping the car from starting?
please
Old 23-11-2006, 07:17 AM
Jay,
Sponsor
Jay,'s Avatar
ginge you have put the chip in the right way round? just a guess !
Old 23-11-2006, 07:20 AM
gingeRS
gingeRS's Avatar
yup, the notches line up so the chip is in the correct way
Old 23-11-2006, 08:24 AM
gingeRS
gingeRS's Avatar
bttt
for the morning crew
Old 23-11-2006, 08:29 AM
Stu @ M Developments
PassionFords Creator
PassionFord Gold Member (Male)
Official PassionFord Trader
Administrator
Stu @ M Developments's Avatar
1st and most likley option:
Did you actually remove the babyboard to modify it?
If so i can almost 99.9% be certain you put the board in at teh wrong end. Leave the 4 pins at the NOTCH end (Nearest side case) Free.
The alternative possibility is you put the chip in backwards mate.
Problem is, if you did its probably knackered now.
Most unlikely option is the ribbon connector is slightly dodgy, just change its orientation slightly and try again, but im sure it will be option 1.
Old 23-11-2006, 08:47 AM
gingeRS
gingeRS's Avatar
just had a quick chat with stu
seems it may be option 3, as didnt remove the baby board and the chip is in the right way round
gonna investigate later and hopefully she will fire up after work
Old 23-11-2006, 12:54 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Hope you sort it
Steve.
Old 23-11-2006, 01:27 PM
Turbosystems
Super Moderator
Turbosystems's Avatar
I agree with stu on option 1 owners often don't like to admit it
Old 23-11-2006, 01:45 PM
gingeRS
gingeRS's Avatar
Originally Posted by Turbosystems
I agree with Stu on option 1 owners often don't like to admit it
i didnt unplug the board to modifiy it
i have plugged the chip in the correct way round.
i checked the connections at both ends of the ribbon connector and they seem fine.
will have to wait till i get home before i can test the ecu, but i hope it is this.
need to get my car up and running again.
Old 23-11-2006, 02:31 PM
Turbosystems
Super Moderator
spoken like a true DIY er roflol
Old 23-11-2006, 02:42 PM
foreigneRS
Testing the future
foreigneRS's Avatar
or a dodgy loom / multiplug (sometimes reffered to as a hairbrush, due to the shape )
gingeRS
gingeRS's Avatar
DIY under stu's instructions
what else can i do?
Old 23-11-2006, 02:45 PM
Administrator
DIY under Stu's instructions
what else can i do?
Stop getting stressed at old Tony's sense of humour. Go home and do what i suggested and you will be back underway in no time.
Old 23-11-2006, 02:47 PM
gingeRS
gingeRS's Avatar
what else can i do?
only messing off home now to resolve it
old man tony
Old 23-11-2006, 04:26 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Have you got it going ?
Steve.
Old 24-11-2006, 06:38 AM
gingeRS
gingeRS's Avatar
got it going fine
but there are other issues
Old 24-11-2006, 06:43 AM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
got it going fine
Thats cossies for ya
Steve.
Old 24-11-2006, 06:55 AM
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
got it going fine
What was the problem that stopped it starting?
Old 24-11-2006, 07:02 AM
gingeRS
gingeRS's Avatar
got it going fine
there is a fault with the ribbon cable from the main board to babyboard. it doesnt always make connections and position is very important.
currently trying to find a new ribbon or babyboard but it is proving difficult
got it started last night, and had it running, went to it this morning, and it wouldnt start
Rob Wells
Ford Mondeo Including ST
18-04-2023 12:19 AM
TPM961
15-01-2018 10:50 AM
xrmalin
13-09-2015 06:52 PM
andrewmctiernan
08-09-2015 03:05 PM
stevierob
07-09-2015 07:09 PM
Quick Reply: weird one.....car wont start
