Does anyone know about boilers??
Old Nov 17, 2006 | 03:57 PM
RSKim's Avatar
RSKim
Default Does anyone know about boilers??
Recently bought a house, not actually living there yet, but i went in today to find a fair bit of water underneath the boiler, i has been switched off for 2 days so though it quite strange....i had a look around and its coming from inside the boiler??
And now the bloody thing won't even turn on, it tries but to no avail
Any ideas????
Old Nov 17, 2006 | 04:42 PM
Redkop's Avatar
Redkop
Think you'd need a Corgi approved person to look at it for you Kim.
Old Nov 17, 2006 | 04:44 PM
RSKim's Avatar
RSKim
British Gas offered me some kind of insurance but i didnt take it out as i didnt think we needed it till we moved in, looks like i was wrong
Look at the Pressure gauge Kim, sounds like its depressurised. hence the water on the floor
Old Nov 17, 2006 | 04:46 PM
Paulo P's Avatar
Paulo P
I only know about bunny boilers I had one for an ex
Old Nov 17, 2006 | 04:57 PM
RSKim's Avatar
RSKim
Rewire It Where would that be, tehres nothing on the boiler itself bar a digital screen that tell you if its on or not
paulpalmer fpmsl
Old Nov 17, 2006 | 05:05 PM
RSKim's Avatar
RSKim
fpmsl everyones on form tongiht
Old Nov 17, 2006 | 05:19 PM
RSCAT's Avatar
RSCAT
my fookers done exactly the same thing, try and pressurize it by adding water and it leaks out again and drops to zilch.
your better off than me though, mine doesnt even try to turn on
Old Nov 17, 2006 | 05:56 PM
escossie560's Avatar
escossie560
What make of boiler and what type is it, a combi boiler ect
Old Nov 17, 2006 | 05:59 PM
RSKim's Avatar
RSKim
erm not 100% on the type, but am going down shortly so could find out, its a combi boiler yeah been told its not THAT old but dont have any onfo with it at all
Old Nov 17, 2006 | 06:02 PM
ian sibbert's Avatar
ian sibbert
Two things that imediately spring to mind if its trying to light...
1. Has the gas been switched off, as you dont live in the property?
2. Is the fan (flue dilution) running when the boiler goes through its cycle?
Ian
Old Nov 17, 2006 | 06:05 PM
RSKim's Avatar
RSKim
The gas has been off, but the boiler has worrked fine for the past week since the gas was switched back on...
Well as above it has been working fine until tonight so i presume so, but im not 100 % sure if im honest
Old Nov 17, 2006 | 06:10 PM
escrst's Avatar
escrst
its not a glo worm by any chance? if so press the button with a curved arrow on it untill it displays the pressure. ie 1.5. if not what make is it
Old Nov 17, 2006 | 07:09 PM
RSKim's Avatar
RSKim
No its a Ideal or a Isra????
Old Nov 17, 2006 | 08:53 PM
se mk3 cabbie's Avatar
se mk3 cabbie
normally on ideal boilers when you power them up and it wont work it will flash up a code on display, then refer to handbook and look for that code under fault finding
Old Nov 17, 2006 | 08:59 PM
RSKim's Avatar
RSKim
i dont have a handbook
well it has started working now, but still leaking water, so gonna have to get someone out
Old Nov 17, 2006 | 09:05 PM
se mk3 cabbie
if it happens again, check code and use this link, fault finding codes are near the bottom
http://www.idealboilers.com/docs/pdf/isar_he_manual.pdf
Old Nov 17, 2006 | 09:42 PM
RSKim's Avatar
RSKim
it doesnt come up with a code at all
Tahnk thought hun
Old Nov 17, 2006 | 10:05 PM
se mk3 cabbie
Old Nov 17, 2006 | 10:18 PM
RSKim's Avatar
RSKim
thast it exactly, but even when it wouldnt power up there was no code
Old Nov 17, 2006 | 10:20 PM
se mk3 cabbie
strange
Old Nov 17, 2006 | 10:25 PM
RSKim's Avatar
RSKim
just my luck
Im sure things will go right for me one day
Thanks for your help
Old Nov 18, 2006 | 09:29 AM
Jon(M600BHP)'s Avatar
Jon(M600BHP)
You deffo need a gas fitter because Isars suffer with leaks and faulty control boards which only a skilled engineer can sort
Same boiler in my house and ive had so many probs with it
Old Nov 18, 2006 | 09:32 AM
RSKim's Avatar
RSKim
just what i wanted to hear
think i may take out that cover with british gas
cheers
geoffxr4
Jan 12, 2007 07:27 PM
danneth
Nov 4, 2006 07:46 PM
RSCAT
73
Feb 21, 2005 04:02 PM
Christian and Beccy
13
Oct 18, 2004 04:53 PM
