help me diagnose my engine problems
Old Oct 20, 2006 | 04:26 PM
gingeRS's Avatar
gingeRS
Default help me diagnose my engine problems
i have 2 minor faults which i wanna diagnose and repair before my mot next week.
fault 1- idles betweem 1500 and 2000rpm, all the time, if you unplug the iscv it idles normally?
will clean the iscv tomorrow, but will it need replacing if so...where from and how much?
fault 2- there is a spot at around 3000 rpm (only really notice it in fifth, 80mph motorway cruising) where the engine splutters, misses, and jerks etc.
if this is the tps, how do i check it, what pins on the ecu are they, coloured wires etc. is it a 0-5v sensor?
any other sugestions as to what could be causing these problems appreciated, if not above
cheers
r
Old Oct 20, 2006 | 05:20 PM
gingeRS's Avatar
gingeRS
pwwwweeeeeaaaaasssseeeee
Old Oct 20, 2006 | 09:40 PM
GUZZLER's Avatar
GUZZLER
gingeRS
1; as you said, try cleaning the iscv first. (new ones are dear)
althoug i do have a new 1 somewere
2; check the plug gaps first, i found it used to open them up after a while.
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
fatboy billy
Aug 3, 2015 08:34 AM
