zetec cambelt change?
really?! i would have thought 40 or maybe even 60, but 80k is pretty high!
its just ive got a minter of a 32k engine waiting to go in the xr, but dunno whether to bother changing the belt yet or not.
80k i would have thought 60K max really. When i had a std 1.6si lump the tensioners onit went around 60k i think . Luckily i pulled over when the tensioners started making a nasty noise and as the cambelt cover was off i saw the belt was really slack and saved the engine. It did slip a tooth though .
I changed my belt and tensioners on my 2.0 lump after only 20k as it had been sitting a good few months after the clutch went as its not worth the risk imho
yeah i had a tensioner let go at about 100mph, bearings had disapeared, it was just the metal inside that bolts to the block, and the plastic wheel bouncing around it. dunno how long it had been gone for but i pulled off the mway and it was making horredous noises, i thought it was the gearbox as it was properly dying also, drove to a mates house, had a look and realised what really had happened sooooo fucking lucky! the cover has got 3mm groves in it where the belt and tensioner was rubbing on the cover! good job it was on or the tensioner would have blatantly come off
this is why i wanna know when it needs to be done, if its not due till 60k i wont bother just yet, but if its due at 40 i might aswell do it now...
yeah i know what youre saying rab, especially seeing as its gonna be seeing the loud end of the rev range more often than the quieter end.
im tempted to put up the phrase if it aint broke dont fix it....but not really the attitude to take towards cambelts
supose i might aswell change it for the 50 quid or whatever it is for a cambelt kit.
Fucking superstar........
Where are you buying your cambelts mate?
Buy the belt, and new bolts for the tensoiner.
thats roughly what it is for a belt and tensioner from a motorfactors aint it?! what do you pay?!
i thought all silver tops were 80k/5 years and the black tops are 100k/10 years?
Also i think it's the ford fusion diesel belt is good for 125k miles!
Mines a MK2 1.8 black top, I'm also wondering when it should be done, its on 66k at the mo but the last owner said it was done at 60k, but nothing to back that up!
JK12
33
26-04-2021 12:09 PM
TPM961
15-01-2018 10:50 AM
