Focus RS closed loop control ????
Old Sep 23, 2006 | 12:42 PM
AndyRST's Avatar
AndyRST
Default Focus RS closed loop control ????
Does the Focus RS run a closed loop control as std?
There is a Lambda sensor just after the turbo. Is it used for closed loop or fuel economy
Old Sep 23, 2006 | 01:23 PM
xrchris's Avatar
xrchris
closed loop is for the warm up phase and i would have thought all modern cars run it. in closed loop it will disregard signals from the lambda sensor and use the preset map in the ecu to control fuelling. once it reaches a preset temperature will switch to open loop and read the signals and adjust the fuelling to suit.
it'll improve power and economy.
hth chris
Old Sep 23, 2006 | 01:29 PM
AndyRST's Avatar
AndyRST
Ahh right, you can feel the switch over from cold map running to warm map running as you drive it from cold. Mt ST170 used to be really bad as it switched for about 8-10 secs it would produce a gentle stutter/pulse. The FRS just switches and and just feel it.
So does the ECU over ride the lambda control if you go full throttle and switch to a programed map for full power running ?
Old Sep 23, 2006 | 01:54 PM
the original's Avatar
the original
same thing/both
wrong way round
Old Sep 23, 2006 | 01:59 PM
xrchris's Avatar
xrchris
same thing/both
wrong way round
i'll give you that one lol, not much sleep last nite but you know what i mean. was always gettin that wrong way round at college when i did pay attention
even on full throttle iirc it'll take a reading from the lambda. it'll switch off any egr systems that may be installed to release full power though.
Old Sep 23, 2006 | 02:07 PM
the original
I don't know anything about focuses
they're different to a cossie then
'cos cossie only uses closed loop on light throttle and below about 4000 rpm (and when hot of course)
else a cossie reverts to the map values
but this post ain't about cossies....
Old Sep 23, 2006 | 02:49 PM
xrchris's Avatar
xrchris
i'm not sure tbh mate, i've been trained on mercs so tryin to think how they work even with them they change all the time with different systems.
it might even be that after a certain threshold they switch to the preset map values but sure i remember them sayin something about still taking a readin to try and retain some economy
Old Sep 23, 2006 | 02:57 PM
AndyRST's Avatar
AndyRST
thats the reson i asked, because i understand a Cossie uses closed loop and then reverts to map over certain % of throttle. I wondered if the Focus RS does something simlar
Cheers for info so far, any more info
Old Sep 23, 2006 | 02:59 PM
the original
how many wires on a focus lambda sensor?
Old Sep 23, 2006 | 04:58 PM
Stu @ M Developments's Avatar
PassionFords Creator
Focus works the same as a YB, which works the same as most other management systems.
To clarify, YES its closed loop as standard and YES they are awfull on fuel as standard too.
Old Sep 23, 2006 | 07:19 PM
AndyRST's Avatar
AndyRST
Yeah they not brilliant on fuel are they stu
What sort of mods has Kenny doen to his FRS and has he found any improvements with the std mapping ?
Old Sep 24, 2006 | 09:52 AM
AndyRST's Avatar
AndyRST
Old Sep 24, 2006 | 11:06 AM
Boost Junky's Avatar
Boost Junky
Upski
Old Sep 24, 2006 | 01:29 PM
Cannot really be improved, its simply a very inefficient engine sadly.
dombanks
Sep 21, 2015 08:38 PM
markk
Sep 9, 2015 08:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
