knife edging a crank? worth it?
im building a zetec turbo, i have steel rods,forged pistons, im lookingto get my crank ground but am wondering if its worth having it knife edged? iv heard its ment to improve the flow of the oil? what are the advantages and dis-advantages of this? cheers
its not the flow of the oil it impoves its the cut of the crank through the oil,,,
think of it a a paddle through water, turned face on the paddle is hard to push through the water
but turned side on it cuts through easily,,,,
same principal with a crank,,, knife edge it to give less resistence when rotating through oil,
Originally Posted by Phil
Has anyone else noticed how almost every cossie you see for sale seems to have a 'knife edged crank'
surely it involves taking material away which weakens the crank?
I just run a windage tray on mine
DANISH cosworth abuser
I have done this to my cranck, and it have given less resistance, the engine rev more easy now, but it have also lightened the cranck and that have helped a LOT, so i can defo recomend it.
My new rods pistons and std knife edge crank are almost 2kg lighter then standard.
(Sorry for my english, not the best description was it )
