zetec engine or cvh turbo engine
alright folks if all goes well i should be picking up a xr2 at the weekend but
i have a full series 1 running gear in my lock up should this go into the xr2 or shall i drop in a rs 1800 lump in, as my old rs 1800 is up for grabs for penauts
not sure what to do
not sure what to do
thats what i thought about turboing the 1800 on standard compression good for about 10psi
on the insurance shouldnt be to bad as im 25 in nov with full no claims (touch wood)
on everday i have used my series 1 for 3 years and my current series 2 for about 6 months
not sure on what to do ill miss the turbo buzz but the rs 1800 was rapid
Fucking superstar........
Either way you'll end up with a smashing wee motor
I'd drop the turbo'd cvh in. Only saying that because I have got a CVH turbo in mine
rab would you be able to send me some pictures of your down pipe as if i do turbo it ill need to reduce the elbow i dont really wanna cut away at the front cross member
Instead of using the downpipe and elbow from your S1, use a saab turbine housing as the wastegate is then on a flat plate rather than inside the elbow.
then take the car down your local custom exhaust place and have them make you a downpipe that clears the crossmember. I used the escort t3 and had to cut the crossmember
Won't be doing it next time though. Saab T3 all the way. Infact the cossie T3 may also have a flat wastegate rather than in the elbow.
Makes better sense dude.
i was thinking of getting it reduced by power flow or someone like that also did you use a fiesta centre fuel tank or a custom one as i still have the series 1 fuel tank that i was gonna cut up and nick the swirl put out of it cheers for the help guys anyway
If I were you I'd buy a small fuel pump, a facet red top or something, and get an external swirl pot. Put em in the boot it'll work sooooo much better and will give no fuelling issues whatever boost you run.
Saying that, the standard tank is fine as long as it's more than 1/2 tank. Anything less than that and you get fuel starvation on left hand bends
i think i would go for the zetec option and turbo that....but im biased....
however, if you want the simplest installation im guessing the turbo route would be a good choice...if you want something different, howabout a zetec turbo, zetec on carbs/TB's?
bassboy
bassboy
bassboy
bassboy
Youve given me an idea cheers mate
bassboy
bassboy
bassboy
JoeyBoyden
04-01-2024 02:36 PM
track.focus'd
12-08-2015 05:53 PM
