Reno 5t carb on my xr2tt. Updated 7-10-06
Old 03-09-2006 | 02:29 PM
Fiecos Dan's Avatar
Fiecos Dan
Default Reno 5t carb on my xr2tt. Updated 7-10-06
Fitted the Reno 5 carb last night.
These is a pic i had of a mates Reno, but he no longer own's it.
i was wondering where all the extra boost/vac hoses go on a R5?
Old 03-09-2006 | 02:56 PM
jameswrx's Avatar
jameswrx
mate, I didn't forget.. I now have contact details for the guy I was on about that can help with this. I'll send him a pointer to this thread.
Old 03-09-2006 | 03:02 PM
Fiecos Dan's Avatar
Fiecos Dan
Old 03-09-2006 | 03:29 PM
dannyblackpool's Avatar
dannyblackpool
Boost Builder
NO1 is deffo the overflow for the float chamber so needs piping to under car, 2 i think is just a vac, think the std boost gauge on a 5 is off that port but not sure
Old 03-09-2006 | 03:37 PM
jameswrx's Avatar
jameswrx
Sounds about right..
I know the pipe nearest the fuel inlet on mine was blocked off (just dog out my old pics)
Not much help, but here's a digi pic I just took of my old engine bay pic I had.
You can just make out the pipe in question (no. 2 as you call it) with a small black pipe which is blocked off
Old 03-09-2006 | 03:44 PM
cahzz's Avatar
cahzz
yup over flow goes to front passenger wing by the death connector.
Old 03-09-2006 | 03:47 PM
cahzz's Avatar
cahzz
heres one i took earlier
Old 03-09-2006 | 03:48 PM
Fiecos Dan's Avatar
Fiecos Dan
i thought number 1 was a over flow,
But pipe 2, on mine isnt sealed, i mean it dont hold boost, or vacum..
The main problem is the idle % co,
Old 03-09-2006 | 05:44 PM
warleydaddy's Avatar
warleydaddy
PM sent..
Pete.,..
Old 03-09-2006 | 05:57 PM
crezzer's Avatar
crezzer
Why dont you use the SU carb from a maestro turbo?? A lot simpler and easier to work with...
Old 03-09-2006 | 06:49 PM
Fiecos Dan's Avatar
Fiecos Dan
i didn't go Su carbs, as when i tried to find out about them, some peep's sed they were Good, but more said thay were crap. Also no one could tell me if the fueling thro the rev's is good.
(edited) And they need to be mounted on the side of a inlet mani, which i haven't got space , whilist using aa cvh carb inlet mani.
So i went for R5 carb, which is meant to be up for 300bhp, and fueling can be tweaked to nearly spot on.
Pete Pm, replyed.
Old 03-09-2006 | 09:15 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Lets hope you sort it Dan
I like your homemade inlet as well
Steve.
Old 03-09-2006 | 10:30 PM
badnews's Avatar
badnews
if it's any help i have this it even has rs on it, i think they are quite rare
well i'v only seen one in a book lol and were thin on the ground years ago
just gathering dust chap yours for the postage if any good to you
Old 04-09-2006 | 06:17 AM
Fiecos Dan's Avatar
Fiecos Dan
Hi Steve,
Badnews, pm sent.
Old 04-09-2006 | 06:44 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Originally Posted by fiesta cossie
Hi Steve,
Badnews, pm sent.
No PM
Steve.
Old 04-09-2006 | 06:44 PM
Fiecos Dan's Avatar
Fiecos Dan
You plonker.
i sent a pm to 'Badnews' the username of the person who posted a pic of the carb.
Old 04-09-2006 | 09:43 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
You plonker.
Doh
Should have the car back on the road on thursday
Steve.
Old 04-09-2006 | 09:48 PM
Rick's Avatar
Rick
SU's are meant to be very good.
Old 05-09-2006 | 03:13 AM
Fiecos Dan's Avatar
Fiecos Dan
Steve, sound good.
Has it been of the road since the fire/ head gasket??
Rick, See my reasons why i chose against Su carb's above.
Old 05-09-2006 | 07:10 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Steve, sound good.
No, done that got it going and it was still not right. Took it apart and found the block was cracked. Sorted that and done a good 700miles and it started to knock so had it apart again, thats now sorted as well and will fit it thursday.
I ain't had any luck this year
Steve.
Old 05-09-2006 | 05:34 PM
Fiecos Dan's Avatar
Fiecos Dan
Thats luck for ya mate.
Hope its ok this time.
Old 08-10-2006 | 11:12 AM
Fiecos Dan's Avatar
Fiecos Dan
UPdate TIME.
- 1st,
i pressure tested the R5 carb to 20psi, and stone me dead, NOT A LEAK, silent. just a few tiny bubbles from the butterfly shaft, (i get the same on my cossie)
- 2nd,
i connected the actuator to a outlet on the carb, (inlet mani boost pressure only)
and now runs with in 0.5 psi from 3500 to 6200 rpm
- 3rd
i've managed to get it running 18 psi after carb, and it fuels 12.3-12.5 :1 AFR from 3500 to 6200 rpm. Thats the best i've seen any xr2 N/A or TT's fueling under full throttle.
Ps its fly's. It feels alot better than when i was running 18 psi on the TT/xr2 carb, purely due to the AFR being correct thro the rev's.
-4th
Theres one major draw back, which i've been trying to sort, and have improved it no end, but still far from prefect.
and thats the fueling on cruise. ITs loves to over fuel, Where as i had my TT carb set at 14.5 - 15.5:1, i was seeing 9.8-16.8: 1 at different throttle positions.
i have since got it to 11.5 - 16:1, But need to get it to 14.0 -15.5 :1 as below 13.5:1 is mega rich for cruise, and bore washing the engine, and above 15.2:1 causes flat spots and hassertation.
But due to the design of the R5 carb its not simple to change, it has fixed jets built in the carb, so i'm drilling this, and spending ages making sure no swarf is still in the carb.
But also i dont know how well a R5 runs off boost, so might be a common thing.
i'm now running, a 120main jet, a 125 air let, a 0.5 enricher fuel jet, and a 1.5mm fixed jet. and a 2.2mm needle.
a std R5 runs 120 main, 125 air, 1.0mm enricher, and a 1mm fixed. and a 1.7mm needle.
i've tried from 1.0 -1.5 mains, 0.5 - 1.25 enricher, 1.0 - 1.5 fixed, and 1.7 - 2.2 needle.
But what i'm using fuels fine at top end, but ok on cruise. with some flat spot's.
- 5th,
i've had to modifie the samco pipe that connects to the top of the carb, as had problems of blowing off, but now cured.
Will get some more pic's up soon.
Old 08-10-2006 | 12:01 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
You in Dan ?
Could pop down.
Steve.
Old 08-10-2006 | 01:55 PM
PAUL V's Avatar
PAUL V
I take it that is your R5 Turbo?? Are you selling ?? i ame after one for my son
Old 08-10-2006 | 02:11 PM
Fiecos Dan's Avatar
Fiecos Dan
Originally Posted by cossie4i
Could pop down.
Steve.
hi, steve.
nice to see you/ and work on your car. lol.
your xr4 pulls stronge,
cant believe how laggy it is, 1.5 bar @ 3050 rpm
and i checked his boost gauge, and rev counter against my accurate ones.
Old 08-10-2006 | 03:32 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Could pop down.
Steve.
hi, Steve.
Thanks for fixing it
The TT XR2 ain't bad either, pulls very hard after 4k
Have to meet up again when we have more time.
Steve.
Old 08-10-2006 | 03:34 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
You forgot to mention it holds it all the way to 6750 rpm
Steve.
Old 16-10-2006 | 08:53 AM
Fiecos Dan's Avatar
Fiecos Dan
After playing with the carb alot on saturday.
i still cant get it to fuel well off boost.
i've manage to get 13.0-13.3:1 on town driving, and 14.0:1 on motorway, and keeping fueling @ on boost 12.0-12.2:1.
But it has a large flat spot @ 3200 - 3600 rpm, under slight acccelaration, AFR goes to 16- 17.0:1, and seems to be were it changes from vacum to boost, I've tracked it back to the enricher diapham set up, but cant cure it/
i've tried everything nearly, and starting to believe thats as good as the R5 boys most do. as never seen a tuned R5 with a AFR fitted.
Old 16-10-2006 | 10:26 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Keep up the work. Some good info and experiance on this thread
Old 16-10-2006 | 10:32 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
You sure?
Main jet, air correction jet, and err, the other jet are all removable and swappable?
Or do you mean other ones?
PS, sorry not text you back, my phone is playing up, nice results tho
PPS, good thread, GT Turbo carbs are ace and the results you getting are why I always praise GTTs, great for sorting the fueling, unlike all other carbs in the world, ever
Old 16-10-2006 | 11:10 AM
Fiecos Dan's Avatar
Fiecos Dan
Cheers Jano.
You sure?
The R5 carb has, and what i've found each do to the fueling.
-a idle jet, Removeable,, just for idle mixture, along with mixture screw,
-a main jet, Removeable, which does slight bit of idle, but more importently consistant throttle steady cruise, and top end.
-a enricher jet, Removeable, which does all throttle position changes enrichment, and top end,
-a fixed jet(not removeable jet) does any high rpm and boost fueling.
- throttle kicker enricher (no need to change at all, and not changeable), does sudden throttle response enrichment to stop hessation.
-a air jet, Removeable which seems to do all fueling.
i've tried 1.00 - 1.50 mains, 120 main is good for round town cruiseing, but toooo lean for higher rev cruise (ie motorway stuff) and anything above 125mm is good for full boost and motorway stuff, but too rich for idle and town cruise.
-enricher jet, from 0.5 to 1.4mm, 0.6mm is best for town cruise, but too lean for motorway and full boost. So 1mm is best ave.
-fixed jet, i've tried 1mm to 1.4mm, 1.4mm seems best, as can run smaller enricher and main, and still fuel fine on boost.
- I've also tried to modifie the way the diaphrams work on the fixed and enricher jets, but changing spring rates and spacings.
also tried them all together in all the different combiations.
The thing is i can get it driving nice on and off boost, but the AFR's say different, as over fueling (but not bogging at all)
Thats why i think R5 boys run rich also, but would like to be proved Wrong.
Old 16-10-2006 | 11:17 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Shithot info there mate, handy too as i will be using a GTT carb again soon
And i think your right about the fueling "issue" my GTT always ran rich (according to lamda, couldnt see or feel it), i ran a 135 main jet (167@wheels@6750rpm@23psi).
Cant remember what sizes the others were now, been years.
Old 16-10-2006 | 11:22 AM
Fiecos Dan's Avatar
Fiecos Dan
Also forgot the needle valve.
Std R5's are 1.7mm but found it to restrict the fuel flow on over 5000 rpm, so redrilled one to 2.2mm, But getting the seal good again was a problem, as i cant find anyone of my usual carb dealers who sells larger ones.
But now it flows enough.
Also cause of the issue of the R5 forum being members only, i could NOT find out info on the carb and what each jet does at all, So everything i've tried is just trial and error, which takes TIME.
Old 16-10-2006 | 03:54 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Well im MEGA glad you found out, well handy, fair play mate
Old 16-10-2006 | 05:10 PM
Spiky's Avatar
Spiky
i used a 140 jet in mine
damm no wonder it puffed a bit of black smoke every now and then
mind i did have 25 psi running trough it
Old 21-10-2006 | 04:39 PM
Fiecos Dan's Avatar
Fiecos Dan
mine runs upto 22psi @ inlet, which is about 30-35 psi before the carb
Old 21-10-2006 | 04:40 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
gotta love that pressure drop
wat was the pressure drop on your XR2 carb mate?
Old 21-10-2006 | 04:44 PM
Fiecos Dan's Avatar
Fiecos Dan
i guess'd the pressure drop then, As not checked it at 20+psi.
But at 17psi, its 25 psi before carb @ 5500 rpm on the R5 carb.
and on the xr2tt carb at 17psi at inlet, its about 21psi. @ 5500 rpm.
This is some data from testing my xr2tt, with R5 carb on low boost.
RPM, Boost after carb (psi), Fueling (afr), ACT's (oC), pressure drop across the carb.(psi)
1000rpm---vac-------14.0afr---24oC---0psi.
2000rpm---2psi-------10.2afr---19oC---0psi.
2500rpm---4.5psi-----12.4afr---18oC---0psi.
3000rpm---9psi-------12.4afr---19oC---1psi.
3500rpm---11.5psi---12.2afr---21oC---2psi.
4000rpm---11.5psi---12.0afr---27oC---2.5psi.
4500rpm---10.5psi---11.6afr---29oC---3.5psi.
5000rpm---10psi-----12.0afr---29oC---4psi.
5500rpm---9.5psi----11.8afr---29oC---4psi.
6000rpm---8.5psi----12.0afr---30oC---5psi.
6200rpm---8.5psi----12.2afr---30oC---5psi.
And compared to the std xr2 carb, which is same pressure drop @ 4000, but 2.5 psi less at 6000 rpm.
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
sridgett
01-10-2015 07:30 PM
Orion_Gav
29-09-2015 04:50 PM
sridgett
13
27-09-2015 06:03 PM
Quick Reply: Reno 5t carb on my xr2tt. Updated 7-10-06
