Freshening up an engine.
Old 25-08-2006, 08:36 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
Default Freshening up an engine.
Right, got this V8 apart and on a stand, gonna give it a quick freshen up as it seems fine, nothing fucked.
Bores look good.
Pistons look fine.
Bearing look ok but ill change the bigends anyhow.
Heads looks ok.
Gaskets were fine but im changine em and the bolts, obv.
Ill change piston rings too I spose.
Is there any other checks I can or need to do to the heads or bottomend?
Also, whats best thing for cleaning/polishing combustion chambers and pistons with? They are sooty as fuck at mo.
Old 25-08-2006, 08:54 PM
AlexF
AlexF's Avatar
change the rings and glaze bust the bores...
do check how much new pistons and a rebore is - you might be pleasently surprised!
Clean the heads up with a brass wire brush and brake cleaner
Alex
Old 25-08-2006, 09:04 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
Whole rebuild kits for these cost next to nothing TBH mate, well, plus shipping.
But I dunno, wanna keep this at a silly low budget to learn how it goes and what brakes when it tastes a bit of boost
Is there any way of checking condition of piston rings? Ie what they look like when a bit worn? Can you tell?
Bearings are easy, but rings?
Old 25-08-2006, 09:06 PM
AlexF
AlexF's Avatar
yes you can measure them with feeler guages
you need to comapire it to a new piston ring to acess if its ring wear or the ring lands themselves!
Alex
Old 25-08-2006, 09:08 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
And I cant do that unless I had new rings, so it defeats the object rilly dont it.
Fuck
No checking the compression seal really now the heads off either is there?
Old 25-08-2006, 09:10 PM
mark
mark's Avatar
change the coreplugs
Old 25-08-2006, 09:12 PM
AlexF
AlexF's Avatar
lol no not really
a leak down test would have been more useful.
You can still measure the ring gaps and look at what they should be on a new ring/piston and make a judgement based on that.
New rings are easy to come buy and fairly cheap.
Alex
Old 25-08-2006, 09:57 PM
...Why dont u just finish the Skyline?
Old 25-08-2006, 10:05 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
I am
But im not doing it.
Car is in a bodyshop in Devon, engine is on a boat somewhere (shipping reciept says was sent aug 2nd).
I like playing with cars, unfortunatley i got way too many
But i love Ford V8s as they easy
foreigneRS
Testing the future
foreigneRS's Avatar
very good advice - you don't know from the outside how rusted through they are
01-11-2015 06:53 PM
Mc5506
05-10-2015 09:57 PM
Chas
05-10-2015 07:13 PM
mondeomark
28-09-2015 06:28 AM
timsrs
22
24-09-2015 08:14 PM
Quick Reply: Freshening up an engine.
