Strange noise changing down gears ....
Old 25-08-2006 | 05:55 PM
Stu.H's Avatar
Stu.H
Default Strange noise changing down gears ....
Car is not causing any problems, no whining, no clutch slip, but it when I change down a gear from say 3rd to 2nd at say 40-50 it sounds just like a car that has been stood for a long time and the handbrake stuck on a bit.
Just paranoia I suppose, but Ive never had a car with a stage 2 bernie box, quaiffe diff and alcon 6 paddle clutch.
The car has only done 2000 miles, but the box was built in early 2004.
Anyone any ideas as its doing my head in.
Oh its more noticable in reverse for some reason
THANKS!
Old 25-08-2006 | 05:57 PM
TIFF's Avatar
TIFF
Chasing Radders
Cossie Paronoia with an RS Turbo...............NO THANKS
Old 25-08-2006 | 06:36 PM
ballin's Avatar
ballin
well mine never did any such thing!
sounds to me like the gear selector isnt adjusted correctly
Old 25-08-2006 | 06:42 PM
Stu.H's Avatar
Stu.H
Cheers Ballin
As long as I dont need to fork out 1k+ on another box
Here, have one of me beers
Old 25-08-2006 | 06:48 PM
Stu.H's Avatar
Stu.H
before u take a sip tho lol, it DOES go into gears perfectly!
only when u release the clutch does it do the noise
Old 25-08-2006 | 10:58 PM
AndyRST's Avatar
AndyRST
Is it like a groan as you lift the clutch pedal up? and once the clutch is fully up the noise stops?
If so its just the clutch material biting and making a groan.
in my experiance AP clutches are notorious for making a groan noise when changing from 3rd to 2nd gear, my AP organic did this noise but it never was a problem
Old 26-08-2006 | 08:21 AM
Stu.H's Avatar
Stu.H
Thats it then.
Cheers people
Old 26-08-2006 | 08:41 AM
ballin's Avatar
ballin
ah I thought you meant it made a knocking sound.
if its the selector then it would struggle to select gears just sat in your drive
TPM961
15-01-2018 11:50 AM
marky_g
12-09-2015 05:26 PM
Adam Graham
06-09-2015 07:04 AM
rsturbo27
05-09-2015 06:08 PM
fordjames
Ford Focus Diesel
03-09-2015 11:20 PM
