stroked engines why ?
Old Aug 24, 2006 | 09:15 PM
leecavturbo's Avatar
leecavturbo
Default stroked engines why ?
what was this idea developed/invented for?
pro's / con's ?
what is the principle?
Old Aug 24, 2006 | 09:19 PM
foreigneRS's Avatar
foreigneRS
Testing the future
to get more capacity out of the same bore, obviously
more capacity = more torque
Old Aug 24, 2006 | 09:25 PM
AlexF's Avatar
AlexF
theres no replacement for displacement.
A longer stroke is effectivly a longer lever to turn your crank so should improve torque like Nick says
Alex
Old Aug 24, 2006 | 09:27 PM
GARETH T's Avatar
GARETH T
BHP =P.L.A.N
p= cylinder pressure
L=legth of stroke
A = area of piston crown
N= number of fireing strokes
Doug's Avatar
Doug
Simple terms
Short stroke = quicker revvin snappier throttle responce
Long stroke = More torque
Regards Doug .
Old Aug 24, 2006 | 09:28 PM
AlexF's Avatar
AlexF
no
bhp = (torque x rpm ) / 5252
Old Aug 24, 2006 | 09:33 PM
leecavturbo
hmmmm, tis why wrc got huge torque ????
Old Aug 24, 2006 | 09:34 PM
foreigneRS's Avatar
foreigneRS
Testing the future
no, that's cos they have huge boost
Old Aug 24, 2006 | 09:37 PM
leecavturbo
through a 34mm restrictor ???? or what ever size it is
Old Aug 24, 2006 | 09:45 PM
AlexF's Avatar
AlexF
because they are high compression engines
Alex
Old Aug 24, 2006 | 09:52 PM
GARETH T's Avatar
GARETH T
its simply because the engines are made to produce massive air flows at little revs
Old Aug 24, 2006 | 10:35 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Boost gives FAR more torque than a bit more stroke mate
Why you think Cossies have WAY more torque than almost all other comparable engines for the BHP
Low compression and high boost isnt just for fun
And YB have WAY shorter stroke than many comparable engines (SR20 etc).
TBH I dont think stroke itself from bore or stroke dont seem to make much odds barring longer stroke often fucks the save revs up as it increases piston speed...
Old Aug 25, 2006 | 08:08 AM
kev 3dr's Avatar
kev 3dr
As above :
Shorter/standard stroke engine proves usually to be a better quicker revving engine due to the speeds of the moving pistons being less of something that has been stroked so helping it travel a lesser distance so being able to turn over more quickly
EG a sorted ford V8 @ 289 cu in (4.7lts) standard stroke with modified/uprated internals will rev to 9500rpm quiet easily at 500bhp
where as
a stroker ford v8 @ 347 cu in (5.7lts) with a custom crank, rods etc will only rev to about 6500 rpm comfortably but produce the same horsepower but an extra 50-75 lb-ft of torque
hopper350
Sep 4, 2015 12:53 AM
Bailes1992
Sep 3, 2015 02:17 PM
Sep 3, 2015 10:49 AM
JamesH
Sep 2, 2015 10:02 AM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
