Broken bolt, cant get the fucker out, help.
DEYTUKURJERBS
Just taking the fannymoulds off the 5litre V8 and all the bolts undid easily barring one, i left it overnight soaking in WD, i heated the fuck outa it, nothing, and finally it snapped off...
That enabled me to get the manifolds off, but I cant get the rest of the bolt out the head!
Its not even flush, its sticking out about 1cm, but i cant get the fucker out still with Molegrips etc.
Any ideas?
Any ideas?
It Wasnt Me!
could hacksaw the sticky out bit off, and drill the remaining part out?
weld a nut onto it and use a socket/spanner?
Use a smaller drill bit than the bolt, and it wont fuck the thread if your carefull, then use a tap to get the remaining shit out of the threads, gotta be carefull when drilling tho
DEYTUKURJERBS
could hacksaw the sticky out bit off, and drill the remaining part out??
It Wasnt Me!
Cut it flush with the head, centre punch & drill
DEYTUKURJERBS
thanks everyone else for advice, just not this unemployable scottish goon
It Wasnt Me!
Stavros, Why on earth would you fuck the thread in the head if you cut the bolt flush with the head. . infact HOW on earth would you do it? ou dont even touch the head. . who's the spaz now
You could try some of this. Seen it the other day at the local motor factors, don't know how good it is.
Loctite Freeze Release (comes in a WD40 style can)
http://www.engineeringtalk.com/news/hec/hec137.html
DEYTUKURJERBS
You cut the bolt flush, that wont cause a prob.
But to get it out, if you just drilled the bolt out, your gonna the threads and need the thing heicoiled or whatnot...
Or am I misunderstanding your meaning of drilling it out...
FastGuy- Looks good, best go get some
Super Moderator
get a dremel type device and flatten off the stud till its flush with the head using a cutoff wheel or grinding head...
use a small drill bit in the dremel to start a pilot hole in the centre..
using diferent sized drill bits slowly enlarge the hole with a drill..
once you get to a drill bit that will drop inside the other holes in the head stop..
go find a tool shop and purchase a tap of the correct size and use that to open up the thread without damage to it. you will not be able to do all of the hole..
use a bolt of the same size to do the last few mm of the thread but remove it once you have done one turn each time and blow out the swarf each time ..
takes some time to do it properly but will be ok ..
i use this method to remove broken studs on presssure vessels that run at upto 2.5 bar
can normally do it in 15 mins so allow yourself about an hour
just be patient and remember the first hole is the most important...
DO NOT cut it off until you've tried these!!!! or something like it!!!
http://www.toolsnstuff.co.uk/product...dd208db472accb
heat the head up like someone said too, then blast the stud with that freeze stuff and get the stud extractor on it!!
Last resort is cutting it off flush, then drilling!!
Super Moderator
If you have never removed broken studs/bolts from castings then you will be better off paying someone to do the job for you.
Someon like these: http://www.helicoilservices.co.uk/
After all you are going to have to buy some decent drills and a 3/8 unc tap to recut the threads and possibly a helicoil set to repair the damage you do when drilling it out. It might even cost you another head.
Unless the bolt is original its also possible it may hardened (I've ARP bolts on both my v8's) in which case you will need Cobalt drills and a lot of luck.
It doesn't help that the bolt holes are angled down so you can't see what's happening or is the engine out?
Don't buy Titanium coated drills they are a waste of money.
Any combination of tips that have already been posted will work if you have the ability.
Most important is to get the true centre of the broken bolt when you drill.
DEYTUKURJERBS
Rene- no im not, im shit
Eagle, KJC- cheers, ill try some stud extractors, that freeze shit, and a blowtorch first i think
Esp as now theres a 2nd bolt thats the same One of the inlet manifold ones
Focus V8- Yeah mate, the engines out, and its reminded me that I really DO like working on cars, but only pushrod ones Its brought me back to the old Renault 5 Turbo days, soooo easy to work on pushrod motors, no fucking cambelt and shit to mess up for a start
Dont spose you know on an online 302ci Windsor workshop manual do you? Need to know head bolt sequence amongst other things...
Not doing major work on it, but thought its prob wise to change head gaskets and bolts, piston rings, bigends, and anything else i see fucked in the meantime.
AFAIK the engines only done 90k so its prob fine, but is still 20yrs old...
Testing the future
fight, fight, fight
as pennywise, it's always good if you suspect a bolt is gonna be a bastard to get out to tighten it a bit first to crack it.
it's too late for that now obviously. i would weld a nut to it, as doing so normally heats it enough to loosen it. but if you can't do that then drilling it out is the best way, but requires care to get the centre of the stud in the first place and to drill it sqaurely all the way through.
DEYTUKURJERBS
EDITED
Eagle- Thanks, shame some nobhead had to try and spoil it
Is that me by any chance??
But you back...
Guest
Posts: n/a
EDITED
But you back...
Just say your sorry and it will be ok
DEYTUKURJERBS
Your just posting more to try and ruin the post more.
If you got a problem PM me or summat, dont ruin perfectly good posts.
And if you not, just stop spamming this thread up.
Testing the future
i meant it's too late to try tightening, rather than being too late to weld it
Keith B i think somebody already suggested easy outs. they're worth a go as they can be done when you are part way through the drilling out process. they need handling carefully so as not to put an uneven force on them though, as they can snap easily
It Wasnt Me!
for you!
did you get it out anyway?
