My S2s compression is 180-190 PSI! :( Will she det at 1 Bar?
Ive just done a compression test on my RST cabs engine and found that all 4 pots are giving a compression reading of 180-190 PSI . I believe the spec of my engine to be :-
1900 (tall block US type) CVH, 88 mm stroke bored out.
2 litre Zetec pistons
standard head and cam (head was skimmed)
Vernier to account for cam timing error introduced by tall block
Although im not 100% sure of this as I got it before I was as clued up as I am now (pistons are defo flat top though).
I found this post from Karl which said :-
"A std ERST engine will give between 150 and 160psi. The same engine with a performance long duration cam will give around 140 to 150psi.
A low comp ERST engine of say 7.3:1 could be as low as 120psi with a big cam.
These are just indicative Psi readings and not to be taken as gospel as I do not want people to be guessing their C.R based on a compression result!!!
These figures are what MY engines give."
So this doesnt sound good for me . Ive been running 8PSI boost for 4 years OK but hoped to raise it a bit (have briefly run it at 1 bar but spark kept blowing out - could that be related??). Not sure what to do now, engines done about 14K and runs sweetly but so I dont want to rebuild it but will she run into det easily if the CR is as high as it looks ??. What is the max boost a standard S2 can run on standard compression?
Any oppinions?
Thanks,
Stu
Any oppinions?
Thanks,
Stu
Am I missing something here?
Surely if all four pistons are giving the same compression readings (within tolerances) then there's no problem? (to a point obviously)..............
Rich, thats true and that is the main purpose of a compression test but Im pretty sure my engine is in good condition, what Im trying to get an idea of is the CR as I dont actually have a clue what mine is and given I dont trust the people who built it any further than I can throw it I wouldnt be surprised if it was running a CR more suited to N/A than a tuurbo application - most people who build ZVHs using the zetec pistons skim them to get a decent CR (or use a spacer) but Im worried I just have some full height zetec pistons slapped ioin there with no spacer and a skimmed head!! thus maybe too high a CR??
I know compression test isnt a v good indication but Im just trying to get an idea as I dont want to take the head off when its running fine.
Stt
Stt
Exactly Gareth and Im aware of the limitations but surely it can give a very rough indication of CR?? (given Im running a standard head, cam and turbo etc etc)
i wouldnt run a bar on std zetec pistons cast jobbers
I see what you mean Stu, bit of a dilema mate
If it helps, not sure it does, mine (1.6cvh) has had 1mm of the top if the pistons and has 150psi on all 4, runs as much boost as my stg 3 T3 can produce LOL.
Nice one Phil, do you have any idea what boost your running then??
That must be scarey in a cabby!!, when I turned mine up it made 241 lbs ot torque - way too much for the super bendy cabby chassis IMO!!
Re-inforce under the sills and sort the suspension and its okay though never had it flat out LOL did hit 148mph once but me balls ran out before me revs did I think my torque is about 260ft/lbs and all four wheels still seem to be on the floor so it ain't that bent LOL
Originally Posted by Jim Galbally
compression test does not in any way shape or form tell you what CR you have... cant even give a rough indication
Thought thats why we drop the cr, to allow us to up the boost, well thats why I lowered mine.
Jim I understand that valve timing etc can have a big effect on static compression but as my car is virtually standard I thought I could gain some kind of relative estimate(given Karl states that a standard RST will produce 150-160psi) - my extra 10+ psi must be coming from somewhere . Oh well will just have to get my home made det cans on and go testing!
Phil, what strengthening do you do??, sounds interesting?, did u fit a strut brace?, Ive heard they can make a big effect on a cab but Ive also heard inurance companies hate them and they can cause the shell to split around the front turretts!!. What suspension are you running?, Ive taken mine back to standard shocks and standard S2 springs (a bit harder and lower than standard cabby ones) + polybushes as she scuttleshook so badly on normal lowering springs - its still damn uncomfomfortable now - I might go 100% standard again yet and limit myself to straight line blasts!!
Re: My S2s compression is 180-190 PSI! :( Will she det at 1
Any oppinions?
Thanks,
Stu
Any oppinions?
Thanks,
Stu
Mark
EDIT...... make sure it's TDC compression stroke!
What engine management and intercooler are you running?
EIL, engine was an full operating temp, just got in from driving home 30 mins before (fan on) then warmed it up again for another 5 mins on idle before the test. Throttle was wide open when testing.
Cheers,
Stu
Pealed an intercooler open like a tin of beans
Mark so I could work out the volume of the head gasket etc with this and then simply work out the rest of the volume using simple maths?, i.e. cyl dia x stroke? type thing?.
Known engine CC divided by 4 gives you swept volume.
Measured clearance volume can be measured with oil.
Swept volume + clearance volume divided by clearance volume is your CR
Mark
Piece of piss mate
Mark
Mark
One thing to bare in mind
When an engine is stripped to do a CR test the ring gaps are sealed with grease to prevent leakage, as long as you don't spend half an hour trying to get some oil into your combustion chamber you will be fine. If you struggle to get the oil in it may be worth trying somthing thicker, this does carry the risk of air bubbles though!
Mark
Mark
I'll say the compression pressure will not limit you going to 1 bar boost pressure. Having a decent IC really helps too. However, you might need a way to retard your ignition advance slightly more when on boost.
