Adjusting boost?
Old Aug 17, 2004 | 09:17 PM
plynchy's Avatar
plynchy
Default Adjusting boost?
Do you make the actuator rod longer or shorter to increase the boost pressure?
Old Aug 17, 2004 | 09:18 PM
Neither LOL
Set pre-load then adjust the bleed
Old Aug 17, 2004 | 09:20 PM
s1rscustom's Avatar
s1rscustom
made mine shorter
Old Aug 17, 2004 | 09:22 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
make it shorter mate
Old Aug 17, 2004 | 09:24 PM
plynchy's Avatar
plynchy
Don't have a bleed valve
Have just come in from garage after fitting my repaired turbo after a 12 hour dayshift,only boosting to 0.8 instead of 1 bar. Bit pissed of now.
Old Aug 17, 2004 | 09:42 PM
wimwerf's Avatar
wimwerf
make it shorter
Old Aug 17, 2004 | 09:48 PM
U don't need a bleed vavle LOL
Just need an amal vavle to adjust the bleed
Old Aug 18, 2004 | 06:17 AM
plynchy's Avatar
plynchy
Enlighten me...didn't know it had any adjustment on it!
Driven into work an hour ago,now boosting at .8 to .9 after i shortened the actuator rod by apprx 4mm last night. Need it sorting before Saturday!
Old Aug 18, 2004 | 07:11 AM
place a restrictor in the middle hole, "C"
The smaller the hole the more boost you will run.
My old amal valve set up ran a cut off welding tip in place to make it run 36 psi
Old Aug 18, 2004 | 07:22 AM
Stu @ M Developments's Avatar
PassionFords Creator
Please note that restricting the compressor port will exagerate the peak boost point. Far better to open the return port substantially first of all.
Old Aug 18, 2004 | 07:24 AM
Agreed stu
This was going on no restrictors in all 3
Old Aug 18, 2004 | 07:25 AM
I figured you were so thought it best to clarify before some goon tries this without a boost gauge just to see what happens
Old Aug 18, 2004 | 07:30 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Old Aug 18, 2004 | 07:31 AM
30psi and bang
My advice is done @ owners own risk or stupidity
Try 2.5mm to 3mm in "c"
Old Aug 18, 2004 | 07:33 AM
plynchy's Avatar
plynchy
So rather than fucking around with the amal valve,can i not just alter the actuator?? Seems easier. I have no desire to run my engine at 4 billion psi,15 will do ta!
Old Aug 18, 2004 | 07:35 AM
If your trying to run actuator load alone you will find that :
A) You may never reach the figure you want.
B) In 5th gear she may melt the engine.
Best do it properly eh?
Old Aug 18, 2004 | 07:37 AM
simple answer then, buy a bleed valve LOL
In car adjustable fun LOL
Old Aug 18, 2004 | 07:42 AM
plynchy's Avatar
plynchy
Here lies my problem,had turbo wastegate repaired yesterday as it wasn't seating properly. Wastegate rod which goes thru the housing was removed to tack bearing sleeve from the inside as this had moved slightly,so the actuator connector on the outside has been welded back on,at(i suspect) a very slightly different angle to what it was originally. I'm guessing tis is why my boost figure has dropped slightly,this is why i figure altering the actuator rod slightly will return it to the original boost setting eventually(trial and error i know). Can't get it set anywhere"officially" before Saturday cos i'm on 12 hour days! Any advice more than welcome.
Old Aug 18, 2004 | 08:09 AM
Neil S's Avatar
Neil S
Run it up in 4th to check the boost levels.
Shorten the rod half a turn at a time, until you are holding a bar, if thats what it used to run.
There are better ways to set boost up, involving bleed valves etc, but this is best left to the pro's IMO.
Having said that, you would probably be safer to leave it and just run it at 0.8 until you get someone to look at it
Neil.
Old Aug 18, 2004 | 08:13 AM
Rick's Avatar
Rick
Explain pls Stu
Old Aug 18, 2004 | 08:21 AM
More load = more boost usually.
Old Aug 18, 2004 | 08:38 AM
Rick's Avatar
Rick
yea i know, but how does bleeding away boost from the actuator help not melt ur engine? Purely because an actuator alone setup holds boost better than a bleed valve setup?
Old Aug 18, 2004 | 08:39 AM
Explain pls Stu
Easy mate,
In situations where folk are running more and more load on teh actuator by going shorter and shorter, you often finmd that under concentrated load when the wastegate is asked to bypass far more volume of air per second.. IE.. 5K in 5th.. the gate will no longer open wide enough as youve removed all its travel capability.
In this scenario, the boost will start to climb higher and higher as the revs go up and up simply because if teh gate doesnt open enough, then the extra air will be FORCED to flow through the scroll into teh turbine and of course spin it harder. This is only normally noticeable in 4th and 5th at high RPM.
Hope this helps... be carefull out there kids
Old Aug 18, 2004 | 08:46 AM
I wish that happened on my t34
Sadly it still tails off....
T4 required
Old Aug 18, 2004 | 08:48 AM
Obviously when we have a well designed engine that consumes more air than our turbo can give it, this boost rise wont happen... lol **
** = It could still melt if it wasnt accounted for in the map and you caused it by meddling with your rod
Old Aug 18, 2004 | 08:56 AM
mmmmmm
LOL
i aint touched my rod tis a bit green
Old Aug 18, 2004 | 09:18 AM
Where's Rick Gone...
Old Aug 18, 2004 | 09:27 AM
Rick's Avatar
Rick
I'm here
Get u now - u mean like people winding std actuators too run 22psi lol
I dont think that my engine has a problem with six whole psi
Cheers Stu.
Old Aug 18, 2004 | 10:30 AM
plynchy's Avatar
plynchy
Have just spoken to the guy who repaired the turbo,(has done thousands of them),and he has confirmed what i suspected,that the position of the actuator attachment in relation to the wastegate has probably altered,hence the drop in boost on the actuators current setting. Looking at the above posts i seem to have a similar trait of tailing off at high rpm rather than the boost increasing,will monitor this VERY closely.
If you see me kicking shit out of the car on Saturday you know why!
Thanks chaps.
Old Aug 19, 2004 | 12:22 PM
Indeed.. roflol
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Fezman1
Oct 2, 2015 01:22 PM
Russ Payne
Sep 25, 2015 08:29 PM
