Think ive just fucked my car...............
Just been out in it had it up to 165mph (on a private road of couse).....and when i pulled up outside my house it had a miss as though it was only running on 3, so i let it cool down then switched it off 5 mins later i went out to pull it on the drive fired it up and got a cloud of white smoke out the back then it cleared straight up but miss was still there
There is no water in with the oil so i am waiting for it to cool down a bit more so i can do a compression test..........
Hope the fu**ers ok so i can goto croft
Right i cleaned the plugs and it runs on 4 again so took it back out and its running fine but when i had the plugs out i done a comp test and these we the results:-
Cyl 1 = 95 psi
Cyl 2 = 80 psi
Cyl 3 = 70 psi
Cyl 4 = 90 psi
So think ill give it another month or 2 on the road then rebuild time before i put the gt30r on for next year......
fucking more money
Cyl 1 = 95 psi
Cyl 2 = 80 psi
Cyl 3 = 70 psi
Cyl 4 = 90 psi
fucking more money
yip engine was warm .........full throttle.............and give it a good few turns till the needle stopped going up
It is a low comp engine but i guess the rings are fucked as there is a bit smoke on over run to
Still runs mint though and pulls like a train .......
Theres no exact figure but imo atleast 10 bar(140psi ish).
A low comp build will have an effect on compression but will certainly not drop it anywhere near sub 100psi. Cam timing and spec will aslo have an effect on the compression results.
well it's fucked got half way croft to croft and it dropped onto 3 and white smoke then as soon as i got on a open road and put me foot down it comes back onto 4 so...........rebuild time....
I thought that about compression but was not sure....but it does not matter now
Don't mine i was planning a full rebuild anyhow over the winter ...........so just means it's going to be sooner rather than later.......
At least i still got to croft
already tryed it mate.....as soon as take foot off throttle it drops onto 3 then when i pull away i get a big puff of white smoke then runs shit for a bit then pulls back onto 4 ......
Originally Posted by lawnsy
don't mind i still got there ...did not realise that was you on the track ..enjoyed watching you
you may have damaged a valve, bent it a bit.
thats why its ok on boost,also the low compression tests.
i did it at Bedford track day.
yip i said head gasket but block wire rung so guess im just thinking the worst............doing to drop engine out in the morning so ill keep ya posted. but comp test was only reading 68psi on number 3 cylinder
deffo over revved it and kissed the valves.
If engine gone it just means bigger better faster
yip lots fill's the road when pull away
fired it up in the petrol garage when i took a lad i know for some chemical metal for his 3 door after he got a water leak ( the black one on the track)
and filled the forcort with white smoke
well if you are happy to sacrifice your engine just to win.......
would rather have my engine.
so i upset him ....as for the engine i was planning a rebuild anyhow because im going to run a gt30 so its justy 2month earlyer than i planned thats all but it was worth i when i got back home and told him i beat him with a fucked head gasket
Mark_
40
02-10-2015 04:40 PM
