what sort of bhp sould i espect???
hi i was woundering if ne1 would have some sort off rough guess of my bhp as iv not had it on the rollers yet
my spec (what i can remember)
2wd- 200 block low comp-7.6
slightly ported head
bd10s
t34 .48
rs500 style itercooler
044 fuel pump
1.5 bar boost (but want to run 28psi)
10mm plenum spacer
greys
thats about it
also i moved the amal valve to the p/s side and used silicone vacum hose
and it turned it self down to 1 bar any thoughts on this would be very helpfull (everything is on right!!!) thanx in advance
bd10s
t34 .48
044 fuel pump
10mm plenum spacer
greys
thats about it
Would of thought with greys you'd be better of with a .63 exh housing rather than your .48.
I renewed my amal boost pipes with silicone ones not ling ago & had the same problem with boost drop off, its to do with the diameter of the pipe must be slightly different to the original pipe,also if you've lengthend them it will alter boost.
Simon.
Simon.
I had to cut a bit off the actuator rod thread so it would allow me to put more pre load on it, not ideal though but otherwise i couldn't run 1.5 bar again.
Simon.
Simon.
Originally Posted by TRAY_25
i think thatll be best at lest i no y now !!! ne1 got .63exhousing???
wheres the best place too go and any ideas on prices ???
South Mark Shead Ma Developments
Midlands Karl Norris NMS
North Stu Motorsport Develpoments
Hope this helps
milton keynes near northhamton should i go bigger ex housing or stay as i am was thinkin about t38 or t4 tho
Mines .48, and its awesome, no flat spots nothing.........
cheers matey staffi no worrys am a bit unsure at the mo every ones advise is helpfull just trying too get me car too a good spec b4 my morgage starts going out as iv bought my on place
