Can someone explain Pectel?
Old Jun 29, 2006 | 10:31 AM
Rick's Avatar
Rick
Default Can someone explain Pectel?
Ok, so Weber Marelli make the IAW used by cossie's. You've got L1,L6,L8 & P8.
Where does Pectel come in, who are they, and why are they needed. You hear of baby boards etc, do the IAW ECU's have an I/O port internally?
Old Jun 29, 2006 | 10:41 AM
Stu @ M Developments's Avatar
PassionFords Creator
I did a great essay on this some time ago, but i bet its been lost.
Old Jun 29, 2006 | 10:46 AM
Taz's Avatar
Taz
Visitor from the Darkside
well find it or do it again.....lol
was it on here Stu???
Old Jun 29, 2006 | 10:47 AM
As you rightly say, Pectel did NOT have anything to do with the original ECU, that was made by Weber marelli in Italy and as std incorporated a lamp output that was capable of sending out flash codes to indicate errors. IE: 10 flashes = CTS. ok?
Pectel, are a company that (i believe) formed in teh 80s and soon became masters of the Weber marelli Ecu systems and their affiliated soft/hardware. Back in the day, the cosworth was fast becoming the engine of choice for fast road and motorsport but the hurdle most couldnt overcome, was making the ecu's run teh modified engines PROPERLY.
Pectel designed a system that would allow people to map it easily, with a DOS based mapping interface. They perfected the mapping and run software and it worked flawlessly in the ecu. The run software like any other, is the "Opertaing System" that runs the hardware that you know as an ECU. PC buffs can liken a chips software to their motherboards BIOS.
This is where Pectel differs from a company like myself, we will make the existing run program do what we want it to do by adjusting its maps and calibrations and then burn the modded program back to a chip, Pectel cleverly designed a whole NEW run software system that bore no resemblance to teh original at all and could be adjusted map by map using the mapping software they supplied to their customers(Pc buffs.. a bit like teh difference between, Award and AMI bios. Both totally different, but with the same end result)
What pectel then had to do was protect all their hard work:
The mapping software (Called IEMS for L1 = 8 and IEMS P8 for P8) was simply that, a software program that would be ripped off in no time. They programmed a dongle for the parallel port and that would ward of most thieves, but still made it a one time only purchase, not exactly business idea of the year, so what they did then was, back in its day, quite unique...
They altered the mapping softwares "Save" program so that when you had finished your maps, and saved them ready for burning to a new chip, the program "Encrypted" the file so it WOULD NOT run in a marelli ecu.
How did you get it to run?
You bought a "DE ENCRYPTION" or "PROTECTION" board that would translate the encrypted message from Chip to ECU. This hardware was copyrighted and only available through Pectel. Now they had a viable product and everytime someone made a new performance chip with thier software, even if they had ripped it off, they had to purchase some hardware from Pectel before it would run an engine. The board is now widely knows as the Pectel Board.
Ingenious.
Hope that answers your questions...
Old Jun 29, 2006 | 11:00 AM
Rick's Avatar
Rick
Thanks Stu - that makes sense. Where does the Pectel board plug into?
How about today - do u still use Pectel's software, or do u work with the marelli program?
What did Ford do for factory backed teams in racing?
Old Jun 29, 2006 | 11:06 AM
Taz's Avatar
Taz
Interesting Stu thanks
Old Jun 29, 2006 | 11:47 AM
Porkie's Avatar
Porkie
Old Jun 29, 2006 | 01:01 PM
The board replaces the board found as Std in teh L8 and plugs into the motherboard on a P8.
We normally use marelli, because we know the software far better and of course we dont need to buy an expensive Pectel board, not to mention the closed loop and other facilities we offer with Weber.... However:
No we offer an amalgamation of the 2 systems allowing you finally to have full closed loop with the benefits that Pectels new software offered such as the serial output and error code streams.. +more.
Old Jun 29, 2006 | 02:14 PM
reality's Avatar
reality
Don't forget that Pectel Control Systems (Pi Research) still offer a large range of professional motorsport ECU's (www.pectel.co.uk)..
Old Jun 29, 2006 | 02:31 PM
Jonzy's Avatar
Jonzy
This is wht makes PF great, you would not get that sorta answer from other fourms. Every days a school day! Top job Stu
Old Jun 29, 2006 | 04:34 PM
The DIVA's Avatar
The DIVA
Interesting trivia,Pectel and P.I Research are owned by Kevin Kalkhoven who also owns Cosworth,making Pectel the sister company to Cosworth.....
Old Jun 29, 2006 | 04:44 PM
gus's Avatar
gus
has kevin kalkhoven got any daughters?
Old Jun 29, 2006 | 04:46 PM
The DIVA's Avatar
The DIVA
If i knew he had,i`d be camped on his doorstep........
Oh and he also owns the Champ Car race series in the USA....
Old Jun 29, 2006 | 04:47 PM
gus's Avatar
gus
brewery?
Old Jun 29, 2006 | 04:49 PM
The DIVA's Avatar
The DIVA
Probably.............
Just hasn`t admitted it yet.....
Old Jun 29, 2006 | 05:52 PM
Rick's Avatar
Rick
Top info, thanks. Not having a cossie, never really thought about it, but it makes sense now.
So who makes the software for editing marelli maps?
Old Jun 29, 2006 | 06:23 PM
THE RADMAN's Avatar
THE RADMAN
stu,why doesnt the pectal run the lambda sensor on my esc cos? surely it would be more benefficial?
Old Jun 29, 2006 | 06:51 PM
foreigneRS's Avatar
foreigneRS
Testing the future
of course it would for a road car, but most pectel boards were designed for motorsport use
Old Jun 29, 2006 | 06:58 PM
THE RADMAN's Avatar
THE RADMAN
can it be configured to run with it then?
Old Jun 29, 2006 | 07:50 PM
foreigneRS's Avatar
foreigneRS
Testing the future
don't know, you'd have to ask someone capable of mapping it
Old Jun 29, 2006 | 07:51 PM
James's Avatar
James
Did the fords motorsport cars use pectel managment then?
what is a baby bored? thats the pectel "DE ENCRYPTION" is it just with a different name?
Old Jun 29, 2006 | 07:59 PM
foreigneRS's Avatar
foreigneRS
Testing the future
a babyboard is so called because it's smaller than the mainboard of the ecu that it's connected to (the parent that does the most work). it may also be called a daughterboard
and yes, in the case of the pectel babyboard, it's function is to de-encrypt eh run program and maps in the "chip"
pectel management - not really as in pectel made ecu's such as they have available now like t2, t6 etc. but i guess that they needed to protect their maps somehow
Old Jun 29, 2006 | 08:33 PM
Billabong's Avatar
Billabong
Yes, there's a software setting to turn lambda on/off.
Old Jun 29, 2006 | 09:18 PM
THE RADMAN's Avatar
THE RADMAN
why did they not do this then when you have the chip fitted,surely it would be better fuel consumption,lower emissions etc?
Old Jun 29, 2006 | 09:21 PM
Billabong's Avatar
Billabong
I don't think many Pectel orientated tuners have bothered with that sideof things - indeed, the same could be siad of most Cossie tuners, until Stu put the time & effort in to develop his lambda package......
Old Jul 4, 2008 | 08:35 AM
BTTT for GRCossie
Old Jul 4, 2008 | 09:19 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
the pectel p8 can run lamda and is a simple byte change, lambda on lambda off.This facility is a must when mapping, you cannot map a car with lambda active
Old Jul 4, 2008 | 09:25 AM
Turbosystems
Super Moderator
Good simple explantion there stu
The webber pectel system was developed for ford motor sport at huge cost.
so back in the 80's and 90's the retail public had the ability to purchase serious software for their road car.
Stu has also protected his maps with an encryption boared to stop the rip off brigade and who could blame him .
Old Jul 4, 2008 | 11:21 AM
foreigneRS's Avatar
foreigneRS
Testing the future
it's weber
nothing is truly protected - you can just protect it against some people
Old Jul 4, 2008 | 11:23 AM
Turbosystems
Super Moderator
it's weber
that is true now but it wasn't in the 90's
the pectel p8 encryption was difficult for people to get hacked took some time before it was
Old Jul 4, 2008 | 05:26 PM
cossiegreg1's Avatar
cossiegreg1
bookmarked for later. havnt got time to read now!!
DixieTheKid
11
Jun 6, 2020 11:20 AM
jessie_rs
62
Aug 6, 2019 09:27 PM
jay030787
Sep 25, 2015 01:38 AM
Steve Cooper
Sep 15, 2015 04:39 PM
hopper350
Sep 4, 2015 12:53 AM
