how hard isit to put an rs turbo engine into a mark 5 escort
well?? how had isit and what parts will i need that i cnt get from the turbo?
PassionFord's crazy fool!
I think you need driveshafts, hubs, half the clutch of an RST and half of a mk5/6 RS2k I think. Probably the EFi Fez RST engine, and the management I think.
Sure I've probably missed something and will be corrected tho.
ive done a couple, it isnt hard, make sure you use the mk5 rs2000 box and shafts if running big power or an uprated rs turbo item, pm me if u need any help. pete
It is a simple conversion.
If you car is mk5/6 running the CVH engine all you have to do is take out the standard CVH and install the 1.6 turbo lump. If its zetec you need to change the left engine mount to a CVH one.
Management wise you can go for the normal Escort RS MFI using the metering unit. But I recommend making your car run the EFI management of a Fiesta RS turbo (OFAB or OFAC).
To run the EFI management you need the engine bay loom from a fiesta turbo or a Escort Mk5/6 with a EFI CVH engine. And you will need a engine with a CPS Hole in the block. You can get this from a late Escort turbo and Fiesta turbo.
Gearbox wise you can run ever the IB box from a S1 RS turbo that has a LSD. Or a MTX 75 box from a RS 2000 and 130 ps XR3i Mk5. If using the MTX75 box you will need to change your HUBs and drive shafts. The standard gearbox IB will cope but won’t take a lot of abuse.
This is a link to some pics of my car.
https://passionford.com/forum/viewto...615&highlight=
If you need any help just ask
Ollie
Ollie
Originally Posted by XR3I 130
Ollie mate was your car originally an xr3i? If so how did you go about yours as mine is an xr so was just thinking about it cheers, Grant ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
If you want to change to a 1.6 CVH turbo you will need a CVH engine mount and that’s it for bolting it up. You can use your MTX75 box and clutch. Plus I think you can use the flywheel off the zetec.
If you want to keep your power steering you need to get a CVH power steering pump from a MK5/6 Escort and drill and tap the holes in the Turbo CVH engine.
Ollie
vdun01
Ford Fiesta
05-10-2017 08:14 AM
