FAO Tuners ??? Zetec Engine Chips & Cams ??
Post Miester !
We are lookin to upgrade the g/f's Fezzy Zetec S..
I was thinking first off, a new chip and a set of uprated cams.
Has anyone had any experience with these ??
Any advice woudl be good
Al........
Al........
Post Miester !
by the time you get a set of cams some headwork and a remap you could almost have done a low pressure turbo conversion on it.
n/a tuning sucks arse
total waste of time really mate
spend a grand to see 10% more power and 5% more torque
spend not much more turboing it to see 30% more power and 30% more torque "ish"
Or failing that a thicker head gasket for less than 100 quid sorts the problem with CR out and the pistons are going to be strong enough to handle moderate boost once the CR is lowered as peak cylinder pressures neednt be much higher than the were to start with
However the vx pistons won't fit in this engine. It is the zetec se and is totally different to PROPER zetec engines
oops, apologies, total for me on the pistons, i didnt read the post properly and was talking about a proper zetec engine
You will still get away with moderate boost on a thicker gasket though
Originally Posted by Garage19
Yup i reckon you could probably runner thicker gasket and nearly and 10/12 psi though there.
If you want cheap tuning, why not give it a sniff of gas?
IMHO nitrous is only any good for making a fast car very fast, not for making a slow car fast.
You would be driving on gas the whole time, and at a fiver a pound or so thats VERY expensive in the long run.
see http://www.shawspeed.com/fsigma.htm
here is a brief description of a friends Zetec-SE currently being finished
"...6500rpm where it's producing a shade over 230bhp and 187.5lb/ft of torque. The torque before this is also impressive as it is making 160lb/ft steadily between about 3500rpm-5500rpm ish so should be very driveable.
Probably won't make any more torque but should get +250bhp...."
Matt, impressive stuff but of little relevance to a standard engine.
Look at thier prices for even the more basic upgrades and you can see the amount of work involved:
210bhp Kit Ł4390.76 inc. VAT
For that 4 grand, garage19 could build you a monster of a turbo engine i suspect
I think to be honest a 110% increase in power for around Ł5k is a bargain
Cant do that to a cossie
I've seen plenty of theses turbo'd as well but not a reliable one for less than Ł5k ..theres better engines to turbo
At the end of the day its is your missus car, so put a new exhaust trim on, tell her its gained 20 bhp and she will tell you how much faster it feels!
Although obviously you can, easily, lol
she would be more likely to tell him to ditch the chavvy crap
I put a chavy clamp on exhaust trim on my missus truck the other day while i was sevicing it. Went down a storm with her horsey crowd before she noticed!
Truck was the only thing i got to service that day
JoeyBoyden
04-01-2024 02:36 PM
