are -6 fittings are the same size as 3/8bsp?
Old 20-06-2006, 06:06 AM
Scott R
Scott R's Avatar
Default are -6 fittings are the same size as 3/8bsp?
As title really, i need to order another fuel regulator, and the only size i can get is either 8mm push on, or -6 screw on. I am using a screw on regulator at the moment that uses 3/8 bsp, is this the same as -6, or am i better off just ordering the 8mm push on job?
many thanks
Old 20-06-2006, 06:34 AM
Tony Ryan
Tony Ryan's Avatar
sadly no , Dash 6 is 9/16th unf .
Old 20-06-2006, 06:41 AM
Scott R
Scott R's Avatar
cheers Tony, looks like i will be oredring the 8mm push on item then!
Dont suppose there is an adapter to change between the two?
Old 20-06-2006, 08:40 AM
RichardPON
RichardPON's Avatar
Yep, there should be an adaptor...........
Old 20-06-2006, 08:58 AM
Scott R
Scott R's Avatar
cheers, will have top look into getting the adaptor then, or i suppose i could change the fuel lines for new areoquip items with -6 ends?
Old 20-06-2006, 09:08 AM
rsnissan
rsnissan's Avatar
indeed you can
Old 20-06-2006, 09:16 AM
georgie1
georgie1's Avatar
indeed you can
andy where can i get adaptors for my fuel filter as i want to run -6 braided pipes from filter to uprated fuel pump which is already aeroquipped with-6
Old 20-06-2006, 09:21 AM
rsnissan
rsnissan's Avatar
Georgie try www.thinkauto.com
I cant remember off hand what size you need as i did mine all over the winter But if you eplain what you have got i am sure they can help you
Old 20-06-2006, 09:24 AM
georgie1
georgie1's Avatar
cheers andy m8
lee2cossies
26-08-2015 10:04 PM
RockinRein
19-08-2015 07:08 PM
rdvil
Other Marques
15-08-2015 12:11 PM
Quick Reply: are -6 fittings are the same size as 3/8bsp?
