Rev Counter
Old 19-06-2006, 05:52 PM
discodenkelly
bounce, bounce, bounce
discodenkelly's Avatar
Default Rev Counter
Put a Stack ST200 rev counter in me car on Sunday and have a few llittle issues with it. I've wired it as per the instructions and set it to work with a 4 cylinder engine but it seems to be showing a lower rev level than the engine sounds like its doing if that makes sense Also, occasionally the needle will bounce or drop down and return to where it was.
Checking the troubleshooting on the instructions it says it could be that the ignition system is providing a low voltage and I need a amplifier?? Or that there could be poor grounding to the ignition system.
Has anyone else got one fitted and had any problems?? Is it just me as usual?? Stoopid car
I've got a grp A coil fitted if that makes any difference
Old 19-06-2006, 07:18 PM
discodenkelly
anyone got any ideas?? Been looking into wiring diagrams etc, from what I can gather the standard rev counter goes into the coil for a reading via the coil supressor. I've bypassed this and gone straight to the coil with fresh wiring like the Stack info said. Will this make a difference to the reading?
Goddam wiring, I hate it
Old 19-06-2006, 08:27 PM
Doug
Doug's Avatar
Take your RPM signal from pin 25 from your ecu that should sort your problem out if its L6 ? .
Regards Doug
Old 19-06-2006, 08:31 PM
discodenkelly
Its a 4x4. thats L8 isn't it??
Old 19-06-2006, 08:33 PM
Doug
Doug's Avatar
Yes L8 mate just checked still the same pin on that too !
Regards Doug .
Old 19-06-2006, 08:35 PM
discodenkelly
cool, I'll splice it in to that and give it a whirl. Cheers Doug
Old 19-06-2006, 08:37 PM
Doug
Doug's Avatar
No worries best of luck mate
Regards Doug .
Old 20-06-2006, 07:17 AM
Sticky.
Sticky.'s Avatar
Never mind the problem, get some pics up of it fitted
TPM961
15-01-2018 10:50 AM
wheelwizardrefurbs
22-09-2015 05:45 PM
wheelwizardrefurbs
18-09-2015 08:59 PM
JoeyBoyden
18-08-2015 05:56 PM
cozzy jeff
14-08-2015 05:46 PM
Quick Reply: Rev Counter
