Actuators.. IS there a difference?
Old Jun 19, 2006 | 02:31 PM
pee vee's Avatar
pee vee
Default Actuators.. IS there a difference?
With -31 actuators, is there a difference between
them for the different turbos? t3, T34, T4??
Rod lenghts weights etc?
and Is there a way of telling what turbo its for??
Got mine at a Show a while ago, (not used it yet lol)
and i can see 31 at the end of the code number,
but just wanted to double check they have given me
the right one for a t34!!
thanks!
Old Jun 19, 2006 | 04:54 PM
dave cos4x4's Avatar
dave cos4x4
they are in different lenghts.
you can alter the lenght by swapping the bit the screws onto the threaded bit.
not too sure on the other Q's.
Old Jun 19, 2006 | 05:03 PM
pee vee's Avatar
pee vee
thanks Dave!
Old Jun 19, 2006 | 05:18 PM
wimwerf's Avatar
wimwerf
I saw a pic from Stu (msd) a while ago...you could see three different actuators...maybe he still has it...
Old Jun 19, 2006 | 05:19 PM
dave cos4x4
maybe...standard, -31, -34.
Old Jun 19, 2006 | 05:20 PM
dave cos4x4
or were they different lenghts
Old Jun 19, 2006 | 06:23 PM
richm's Avatar
richm
there are 3 lengths - very short for Escos, medium length for 2wd and long for 4x4.
the other variable though is the length of the turnbuckle that attaches to the wastegate arm, so by juggling the two there are a few combinations that can be achieved to reach the same goal..
Old Jun 19, 2006 | 06:28 PM
pee vee's Avatar
pee vee
ah i see. but ultimatly all -31s will open at the same pressure?
Seems a bit of a silly question when i put it like that
thanks Richm!!
Old Jun 19, 2006 | 06:29 PM
richm's Avatar
richm
yes I believe so, only the physical dimensions that vary.
Old Jun 19, 2006 | 06:33 PM
pee vee's Avatar
pee vee
dont need to worry about that being wrong now then!
Old Jun 19, 2006 | 06:41 PM
Billabong's Avatar
Billabong
8 psi liftoff for -31, higher boost achieved by ECU & amal valve/other boost control.
wowk
Mar 30, 2021 07:49 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
SMILER258
Sep 28, 2015 09:04 AM
Sp3no
Sep 27, 2015 07:23 PM
little bram
Sep 27, 2015 07:45 AM
