cosworth 2wd hydraulic clutch conversion
Caraholic
No £400 is supply of the parts only for a 2wd, is cheaper on a 4x4 as the bell housing doesn't need modifying by Martin, it can be done by anyone with a drill.
The clutch plate and cover denote power capability, not how it is actuated
Hydraulic actuation removes the hit and miss operation of the standard cable / ratchet mechanism. Gives a lovely feel to the peddle and more importantly self adjusts properly to remove any wear from dragging etc.
The standard ratchet mechanism isn't really up to the job of taking the force that the paddles require and can drag or worse snap the ratchets / stretch the cables.
![Raz](https://passionford.com/forum/images/smilies/tongue.gif)
Caraholic
Yep, flywheel must be ground EVERY time a paddle is fitted. This is because the normal slipping of the clutch process will cause hot spots on the flywheel, which are slightly raised and the paddle will grab onto these when a new one is fitted. This makes it difficult to get into first gear and makes the car a pig to drive etc.
so hydraulic is easier on the leg then? just asking as the next cos will need a paddle clutch and the missus will be driving it and I dont want her to have one man size leg and one girlie leg
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
I have a hydraulic clutch , i am useing AP racing heavy duty clutch cover , and an alcon 6 plate paddle clutch.
the feel of the pedal is lighter than a 1.1 fiesta it's that soft you wouldn't even think that you had a heavy duty clutch in the thing
shows you how much Ima knows, what do you expect form a buffty road racer
McCleod make a hydraulic release bearing/Slave cylinder for the T5's used in Mustangs.
Maybe its usable in the Cossie T5's and would make the swap easier.
FlashRS
13
31-08-2015 06:02 PM
