Turbo rebuild versus new one
Old 15-06-2006, 02:02 PM
The Sludge
garibaldi
The Sludge's Avatar
Default Turbo rebuild versus new one
is it acepatble to simply get a turbo rebuilt, or am i better buying new?
Wheres the best places, or i presume Turboi technics direct is the place to go to???
Old 15-06-2006, 02:11 PM
COMEDY DAN
No1 Blower.
COMEDY DAN's Avatar
I used to buy for 6 years from turbo technics and never had one problem at all.
For any rollerbearing units I recommend turbo dynamics.
Old 15-06-2006, 02:21 PM
bud-weis
Football Cwazy
bud-weis's Avatar
i've always had mine rebuilt,they are practically new when they come back anyway
Old 15-06-2006, 04:56 PM
The Sludge
garibaldi
The Sludge's Avatar
cheers Its what i thought anyway tbh.
Old 15-06-2006, 05:26 PM
Rab
Fucking superstar........
Rab's Avatar
Yeah mate, get it rebuilt. TT and Univeral Turbos I've dealt with and have both been spot on
Old 15-06-2006, 06:56 PM
Rick
Rick's Avatar
depends, it the wheels are mullered, or cracked zorst housing, or worn bearing housing then u will need a new one.
Old 15-06-2006, 07:00 PM
dannyblackpool
Boost Builder
dannyblackpool's Avatar
as rick really, if all major components are in spec then should be no problem
Old 15-06-2006, 08:20 PM
gibbo frst
gibbo frst's Avatar
has anyone had a turbo where the wastegate arm goes real tight even after opening a few times with pliers still sticks??.. t34?
Old 15-06-2006, 08:55 PM
dannyblackpool
Boost Builder
heat usually causing wastegate arm to bend
Old 15-06-2006, 08:56 PM
dannyblackpool
Boost Builder
Old 15-06-2006, 09:15 PM
gibbo frst
gibbo frst's Avatar
i dont think anything is bent .. was fine when i parked the car up but was 8 months ago.. noticed was tight when i took turbo off so lubed it a bit but after driving a few miles with turbo getting hot has gone tight again..
Old 15-06-2006, 09:30 PM
murdoch1.7zs
murdoch1.7zs's Avatar
yip mines done that. got another elbow on it now
Old 15-06-2006, 09:34 PM
gibbo frst
gibbo frst's Avatar
bit of a shit really as its only done 1k as i brought it brand new from garrett.. no warrenty now as been over a year...
Old 15-06-2006, 09:39 PM
murdoch1.7zs
infact the problem with mine was the little coin thing was slack and was hitting the inside of the elbow and causing it to stick.
if you take it off and try and get it a bit tighter it would be fine. but no so tight that it doesnt move. so it can seal onto the housing properly
Old 15-06-2006, 09:45 PM
gibbo frst
gibbo frst's Avatar
it all looks like new inside still just basically where the shaft goes through the housing feels as if it needs lube.. is as good as new with a squirt of grease but burns off in seconds... it must have just been where its been sitting for 8 months..
JK12
33
26-04-2021 12:09 PM
Ford Focus RS Parts for Sale.
02-06-2016 06:46 PM
Matt Baxter
16-09-2015 08:30 PM
kevin36
02-09-2015 06:24 PM
rsturbo27
01-09-2015 09:54 PM
Quick Reply: Turbo rebuild versus new one
