Anyone used a Battery Cable Junction box???
Its a little black box with usually 2x or 3x 8mm ternials studs inside.
You can then connect the battery cable to the studds and any extra wiring accessory circuits.
Ive got a number of circuits running to the battery such that there are a lot of wires on the battery post. So thought one of these would solve that.
Anybody ever seen or used one???
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
Depending on the number of connections and the gauge of the cable - you can buy battery terminals for ICE installs that can take 2 x 4AWG, 2x 8AWG and 4 16AWG for about £5 from Maplins
And i want to try and get the extra wires away from the battery post.
With one of these junction boxes I could have one cable to the post, the other extra wires all into the junction box on the bulkhead........
Standard fit to BMW's i recall, as they have the batteries in the boot.
i'm going to fit one in my xr2 turbo when i get round to getting some decent cable
can get them for pence from most breakers yards , just look for a newish bmw
As said, even the old bmw's had these in the engine bay.
Mk5 escorts had a little fuse box that bolted directly to the battery terminal which then had about five 50-100amp fuses inside. then you can attach wires to the other side of the fuse terminal using a bolt and a eyelet terminal to then run off to your circuits.
Makes the whole lot look tider and it's all fused aswell.
