What production turbo cars run carbs??
i know of the Reno 5, and metro turbo versions,
But both are to small for my needs,
i'm looking for a new carb for my xr2tt, that wont be a restriction at 230+ bhp.
Any idea's??
I looked at a reno 5 gpA carb today, and its smaller than wots already fitted to my car.
Any idea's??
Yeah meastro, montego and metro's all run Su's i think, but been told be a mechanic mate that they are crap carbs??
Does anyone know the spec on them? eg the venturi sizes??
Most turbocharged Beetles are still on carbs... I know they're not production cars, but you might be to get some information from them. John Maher Racing has done it before, I'm sure.
Originally Posted by boXXer
a few people have turbo'd twin carbs, i.e 45-48's, although i think you need special turbo specific ones, but im not totally sure/ Seen it done on a few mk1 escorts though ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
the problem with twin 45 etc ect, is the time for jetting, the maintenance to keep them running sweet.
also i think twin 40's would be well up for the airflow.
Anyone got links to above info?
Danny
Originally Posted by richm
Early Lotus Esprit turbo used sidedraught dcoe/dhla
Originally Posted by Ratty
Nothing wrong with turbo SU's
Pic of mine and jasesapphy's twin carb turbo engine
![](http://www.chippers.me.uk/gallery/gooon/engine.jpg)
Hi,
so wot power is a single SU good for? Why are you running 2?
Originally Posted by GAZ W
Mine wasnt a production carb turbo car but here is the setup it used to run
![](https://img.photobucket.com/albums/0603/gaggler/turb1.jpg)
![](https://img.photobucket.com/albums/0603/gaggler/turb.jpg)
there was a few 7.2 cadilac turbos, they had some monster carbs on them , and a fwd v8 lincon i think, carb turbo
Hi,
I need to get the car on a decent rolling road as it pegged the 200bhp rolling road it went on
The Maestro did a 13s 1/4 with big traction problems (spun for the first 1/8) so hopefully some new adjustable tca's should help resolve this as I can reduce the camber
Cheers lads.
Ratty,
can the fueling be fine tune'd to say 11.5 - 12.0:1 AFR thro out revs whilist on full boost?
Any problems with them?
as i have a mate who hate's them, a mate that love's them, and i spoke to a local RR tuner, who didn't like them either.
What are they like for leaks under 25psi boost??
Ratty,
Tuning carbs is always a compromise its not like having injection and a proper fueling map, but to control on boost fueling use a rising rate fuel pressure regulator. I've heard of people running 2 bar through SU's but unless its been rebuilt with new seals dont even try it
Only issues I have with mine is cold start due to 2 independant manual choke cables, but as its left ticking over until I'm off choke before driving off I dont worry
Setting up is an art (same with injection) and getting someone who knows and can size the correct jets needles etc is the key
Biggest problem with carbs in general is people never service them and expect a 20yr old carb to perform like new
Also make sure you get a proper turbo carb, plenty of n/a ones passed off as sealed turbo units
Any idea's??
Any idea's??
Other options, if you search the states, are Weber IDA40 converted to blow through setup. Basically they upgrade all the seals and spindle ends, and fill the float chamber to stop it from crushing..
The other option is a usual off the shelf carb, and incase it in a presurised box (so equal pressure on the inside and out side of the carb, so no fuel will leak past the spindle seals - as used in the old Bentley Turbos)
Cheers Ratty and Dave,
i did think about enclosing the whole lot, but decided not to, as alot of work, also the work needed to seal the throttle cable, wires and coolant hoses, and make the a set up, where the carb can still be serviced with out to much hassle.
big_Rad
15-09-2017 09:36 AM
