Crank pully
#41
Former Sponsor
the end of the crank is exceptionally strong,it will take some effort to damage it,if in doubt use a 10p peice,
you dont need a puller to remove the crank pulley,just two tools that everyone has in there tool box,takes less than thirty seconds as well.
tricks of the trade.
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
#44
Former Sponsor
a wood work chisel,just run it down the back of the washer between the cambelt pully,ive only ever needed to use a puller on about three wheels ever and i must have took over 400 of these off easily,iam still useing the same chisel,some times you need a new washer but very rarely,the little cambelt pully can be a real pain though,carefull or you will break the alloy seal plate,but why do you want to even take it off?
#45
I've got a feeling the crank case seal needs replacing......... Its very dirty around the lower front area, and i think its coming from there.
Also is it ok to use a little film of copper grease on the shafts when putting these pulleys back on? Its gott make life a hell of a lot easier......
Ps that crank was an utter bit to remove!! I thought i'd broken it once it freed itself!!
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
#46
THATS the one i needed the heat for............................
ended up using a puller on the bloody ally cover in the end and pulling that of (taking the small toothed pulley off with it!)
DixieTheKid
11
06-06-2020 11:20 AM
timsrs
22
24-09-2015 08:14 PM
