Cold Start probs
Old Jun 1, 2006 | 01:05 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Default Cold Start probs
When i start my car from cold, the revs just fall flat. Theres no raised revs for a min or so like there should be and i have to sit there holding the revs at 1500 until she starts to get warm.
I tried my iscv which i thought was the problem in another cossie and it worked fine so it cant be that. Im getting voltage to the plug that controls the iscv. Have changed the blue water temp sensor at the back of the head but no difference. Can anyone shed any light on it please?
Rich
Old Jun 1, 2006 | 01:29 PM
CossieRich's Avatar
CossieRich
anyone?
Old Jun 1, 2006 | 01:35 PM
bud-weis's Avatar
bud-weis
Football Cwazy
faulty chip
Old Jun 1, 2006 | 02:29 PM
CossieRich's Avatar
CossieRich
No chance of that. It was doing it on the greens conversion as well
Old Jun 1, 2006 | 03:03 PM
Ryan's Avatar
Ryan
faulty loom
Old Jun 1, 2006 | 04:35 PM
CossieRich's Avatar
CossieRich
tossers the pair of you
any serious answers please
Old Jun 1, 2006 | 04:36 PM
Jim Galbally's Avatar
Jim Galbally
i'd say faulty loom too.
if the ISCV works fine but not in your car then youve either got a SHIT chip, a FUCKED ecu, or a dodgy loom.
Old Jun 1, 2006 | 04:39 PM
Ryan's Avatar
Ryan
mine was actually a joke
but he could be right you know rich.
only 4 possible things it can be.
ECU ?
Loom ?
ISCV - Think you said you've already ruled this one out
Another Sensor (ATS, WTS) ??????
Old Jun 1, 2006 | 04:44 PM
CossieRich's Avatar
CossieRich
The connector was checked with a noid light and it lit up so i thought that would have ruled out the loom.
Jim you obviously havent been keeping up with my big post on having my car set up. Do you know what chip i have
See my sig
So that leaves the ecu which i doubt seeing as there doesnt seem to be anything else wrong with the car.
WTS is new
Old Jun 1, 2006 | 04:47 PM
Stu @ M Developments's Avatar
PassionFords Creator
Try it with the wires on teh ISCV valve reversed in case someones fitted teh wrong valve at some point.
The cold start system requires CTS, MAP sensor and TPS to be perfect.
The Positive to the ISCV is shared with teh fuel pump and amal valve, the negative is supplied by the ecu to create a valve position.
Old Jun 1, 2006 | 05:11 PM
CossieRich's Avatar
CossieRich
Stu,
Will give that a try. Is there any markings on the iscv that may give it away if the wrong type has been fitted? The amal valve clicks when you disconnect and re-connect so obviously the postive side of things is working ok.
what is the CTS?
Old Jun 1, 2006 | 05:22 PM
abdr500's Avatar
abdr500
cts is coolant temp sensor
Old Jun 1, 2006 | 05:28 PM
CossieRich's Avatar
CossieRich
cheers pal .
that is fairly new as well
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
gingeRS
Sep 4, 2015 06:29 PM
