A t34 with a 63 housing and a /34 actuator
Old 01-06-2006, 08:47 AM
abdr500
abdr500's Avatar
Default A t34 with a 63 housing and a /34 actuator
A t34 with a 63 housing and a /34 actuator i have the rod adjusted all the way till the end and will only make 1.6 bar is that actuator problem
Old 01-06-2006, 08:58 AM
abdr500
abdr500's Avatar
up
Old 01-06-2006, 09:05 AM
Ish
Ish's Avatar
you have bumped your post up because you hadn't had a reply within 11 minutes of you posting
p.s is your name Abid? It's just that someone mentioned that there is a guy called Abid who classes themselves as a cossie specialist around his area but in reality he gets all the info on how to repair customers cars off the internet
I'm not saying that is you but the i'm sure the person who mentioned it said it was around the same area you are from?
Old 01-06-2006, 09:07 AM
abdr500
abdr500's Avatar
Ish
and your point is
Old 01-06-2006, 09:12 AM
RS500/364
RS500/364's Avatar
You go on about your customers all the time and all the time you ask tech questions how do you get these when you always need to find the aswers on here
what do you do for your customers?
Old 01-06-2006, 09:30 AM
abdr500
abdr500's Avatar
RS500/104
life is all about learning m8 i just want a second opinion befor i go and buy a new actuator
Old 01-06-2006, 09:34 AM
Ish
Ish's Avatar
just incase you missed my question the first time round!!
Old 01-06-2006, 09:35 AM
RS500/364
RS500/364's Avatar
that can cost more money than a pro doing the job in the first place !!
Old 01-06-2006, 09:47 AM
abdr500
abdr500's Avatar
Ish
i am not asking a tec Q m8 but a second opinion on it
i use this form because it can be of great help some times but will never work/fix a vehicle on what people say on here. as that judjement is best left the person that working on the car
Old 01-06-2006, 09:48 AM
abdr500
abdr500's Avatar
RS500/104
yes i know i must have to much money then
Cosnada
07-01-2016 05:30 PM
fordrallycar
30-09-2015 07:57 PM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: A t34 with a 63 housing and a /34 actuator
