ZVH Engine problems
Old May 18, 2006 | 08:51 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
Default ZVH Engine problems
Right chaps been helping a mate out with a poorly 2L ZVH
Problems are very lumpy running like on 3 pots, loads of black smoke at 1200 rpm as will not tick over, sooty plugs.
swopped all parts for known working items:
plugs and leads
dizzy cap and arm
injectors.
Engine has never been run and is using a ferriday decomp joint @ approx 7.5-1. Using MFI turbo injection, std cam and ecu at the mo.
Tried disconnecting the cold start valve but no joy. Valve timing is a close as it goes with out a vernia on a ZVH.
you have to turn the dizzy right round to start it but then adjust to keep running and then will not restart in this possition
Only been ran for short periods at tickover and 3000 rpm as something is wrong big style. My head is fried now and need some fresh advice.
Cheers for any help / suggestions.
Bri
Old May 18, 2006 | 08:59 PM
Šhatter Box's Avatar
Šhatter Box
metering unit
Old May 18, 2006 | 09:02 PM
*Bri.4.b.Cos*
thats what i was thinking adjusted the mixture a bit and the revs picked up a bit but still clouds of black smoke. However the metering unit come off a working rst but been sat about 6 months
Old May 18, 2006 | 09:05 PM
Šhatter Box
well u know its over fueling so that would be down to the mixture screw try an other one just to be sure imo is it missing badly ? and hows the timeing?
Tim's Avatar
Tim
or the plugs are on the wrong way on the back of the engine water temp thermo time switch etc seen it loads just buckets out fuel lol
Old May 18, 2006 | 09:09 PM
*Bri.4.b.Cos*
All the injection system come off a working rst but been sat ages. plugs on right way at first pot 1 was flooding and soaking the plug really badly and slightly on pot3 but sinse turning fueling down a bit all plugs are now dry but really sooty. It sounds like its running on 3 and when you remove the plugs and fire it over bucket loads of fuel comes out
Old May 18, 2006 | 10:20 PM
rsmycase's Avatar
rsmycase
have u checked all the ignition leads are in the rite firing order?
Old May 19, 2006 | 08:40 PM
king of bling's Avatar
king of bling
Default zvh
Now bri should have had me build it no probs with beefys lol. Did you say that you are useing a decompression plate if so they are shit mate and could be the probelm also sounds like the timeing.
Old May 19, 2006 | 08:54 PM
*Bri.4.b.Cos*
Nothing to do with decomp or timing IMO, seen plenty of these buggers going strong. Management must be at fault, will be replacing metering head with a new recon spare and swopping all sensors plus jusr found out the petrol has been in the tank 18months so that wont be helping too much
Bri.
Old May 19, 2006 | 10:33 PM
Number1's Avatar
Number1
so whats been done to the car? mfi conversion? or is it a true mfi rst? iirc theres a wire that can get misplaced and cause it to overfuel on the ignition, as i think mfi has a start-up enrichment circuit, if thats not correctly fitted it will over fuel like a bastid, mate had a mk5 turbo and we changed everything when it was overfuelling, also started when you held the dizzy right over one end, would run for about 5-10 mins on the spot before the plugs fouled sounded like it was on three too.. i shall speak to him to find out what wire, basically tho he wired it up using a fiesta turbo diagram but a couple of wires are different
worth a shot, if not pm safechav he's real good with wiring probs
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
Blown Hell
Aug 5, 2015 07:22 AM
