hi just a littel discussion about cossie alloy bottom pully
hi just a littel discussion about cossie alloy bottom pully with the lugs on it was told buy some one that realy now his stuff .(you know who you are )
.that they are shit and cause all sorts of running problems .who has one fitted and did they have problems as i have one and the car in genarly feels shit
isnt there a sensor which gets its timing off of that pulley?
if that is the case, then an alloy pulley, being non-conductive, will screw the sensor up
Originally Posted by abdr500
GARETH T
the one i have has a littel steel cap
is the sensor too far from the pulley?
or more likely, (not sure if this is right, or if I am explaining it very well, but) the sensor works by sensing a 'hole' in the steel pulley at one specific point, so does the metal cap run all round the pulley and have a small 'gap' in it at all? is that gap EXACTLY at the right point on the pulley
does that make sense at all?
if that is the case, then an alloy pulley, being non-conductive, will screw the sensor up![Top](https://passionford.com/forum/images/smilies/smile011.gif)
but im sure you ment ferrous
SPLADGE
you must love my post m8 you have nothing better to do![Top](https://passionford.com/forum/images/smilies/smile011.gif)
If you have a poorly made alloy bottom pulley then bin it and put a perfectly good standard one back on, problem solved!
It may not have the same impact when you drop it into conversation as when you say 'but i have an alloy pulley on my YB' but it will work a lot better
