French Ford Forum
French Ford Forum
Hi!
I live in Paris, my technical language is not very rich, and it's difficult for me to explain problem, feeling about my car in english...
That's why I'd like to know if you know french FORD forum ?
Please help me...
Thanks in advance....
--> i have a big problem with my Water Pump...
Please help me...
in french...
Je suis ŕ la recherche d'un forum Ford mais en France, et en Français !
Mon vocabulaire technique n'est pas tres bon, donc ce n'est pas tres évident de m'expliquer en Anglais...
Voila mon probleme :
J'ai voulu changer la pompe a eau de ma Fiesta, et une vis ŕ foirée (impossible de retirer).
Comment puis-je faire ?
- Dépose moteur ? --> Comment on fait ? --> Mon garagiste le fera je pense... mais ça risque de couter cher ?!!
J'espčre trouver uun forum en Français...
Merci d'avance... et tres bien votre Forum !!!
I am looking for a Ford forum in French!
My technical vocabulary is not very good, therefore this is not very easy to explain in english...
Here's my problem: I wanted to change the water pump on my Fiesta, and a screw has failed (impossible to withdraw).
What do I do?
My mechanic can do it I think... but thats expensive?!!
I hope to find a forum in French... Thank-you in advabce... and well done for your forum!
What do I do?
i think that basically translates to he is trying to change water pump on his fiesta but he cant remove one of the screws. he wants to know how he can remove it and if it is likely he will have to remove the engine.
he says he can get a mechanic to do it but it will be expensive.
He is looking for a french ford forum if anyone can help?
thanks in advance and great forum
summat like that anyway
salut Edouard, je suis le webmaster de PF, et je suis francais... quel est ton probleme de pompe a eau, je le traduirai pour que tout le monde le comprenne et tu verras que tu auras une reponse tres rapidement
Salut, j'habite en angleterre, mais je parle francais
Je ne sais pas ou la vis se trouve (je n'ai pas de fiesta), mais une depose moteur complete me parait un peu exageree...
Il existe un outil qui permet d'extraire des boulons arrondis, tu fais un trou dans la tete du boulon avec une perceuse, et tu vis un truc conique dans le trou.
Le truc conique se vis dans le sens inverse des aiguilles d'une montre, et plus tu le visse, plus il accroche au boulon, tu peux avoir deux resultats...
1. Ca marche et le boulon sort ok
2. Ca marche pas, et tu eclates la tete du boulon, ce qui le rend encore plus difficile a enlever
Ce que je ferais...
1. Mets plein de lubricant penetrant sur la vis (genre 3-en-1), et laisse-le agir pendant la nuit.
2. Avec une perceuse et une meche assez grosse, perce la tete du boulon jusqu'a ce qu'il ne reste que le boulon lui-meme.
3. Tu devrais alors pouvoir enlever la pompe a eau.
4. Enleve le reste du boulon avec un paire de pinces etau.
5. Si il ne vient pas, un peu plus d'huile, ou, un peu de chaleur (chalumeau) peut aider
Une petite photo serait utile, on pourrait voir ou se trouve la vis et si ce que j'ai dit est faisable.
Bon courage.
Ce que je ferais...
Bon courage.
Ce que je ferais...
Bon courage.
Ce que je ferais...
Bon courage.
Well done Greg
bonjour compagnon, je pense qu'est ce pour ce que vous pouvez ętre regarder...
http://ford.rs.free.fr/forumphp/
steerfromdarear
28
29-01-2016 07:14 PM
borboyous
22-08-2015 12:17 PM
