Any one fitted concentric top mounts with coilovers ?
As topic need help
Do uou still use any of the origional top hat or bearing from the origional suspension ?
Or is it a case of binnin the lot and offering your coilover with spring cap upto the new mount with the collar on the underside and the new nut on the top ?
Thank you please Doug .
Originally Posted by Tony Ryan
Very pretty mate ! Bit overkill tho , normally 3 bolts holds em in ! Right idea tho , a top hat to centralise the strut and a nut in the top to stop it moving ,
Rather be safe than sorry
The tw@t ain't moving baby
Lots of bolts there Thought i was using to many with 4 bolts. Not got the coilovers fitted yet as i olny just got a set for Paul (NYRS spares). Pics are the standard 4x4 strut.
sorry if i'm being stoopid, but aren't they eccentric top mounts rather than concentric? if not, what's the difference?
They look pretty much the same as the ones on my mk2 and i'm sure they're eccentric.
Mine are eccentric type.
The difference is that the hole for the strut is off centre with the eccentric ones and the concentric are in the centre as per the rubber doughnut.
Eccentric not usually used on road cars. You realy need to have fully adjustable front suspension to make good use of them i.e. adjustable tca's and compression struts.
matman
09-09-2015 05:45 PM
saph in dorset
14-08-2015 10:10 AM
track.focus'd
12-08-2015 05:53 PM
