Bias pedal box mounting..? this ok?
I just bought this bias pedal box off dangerous - reyland for the 3dr and need to obviously make something up to mount it.
will this type of thing be ok?
bearing in mind the only forces are pushing it towards the bulkhead, but would it be best to join the two bits together?
pedal box
![](https://www.rallydesign.co.uk/catalog/images/PEDALB.jpg)
shit pic thats come out really small
![](https://i69.photobucket.com/albums/i65/FastFudge/brakeplate.jpg)
anyone
pedal box
anyone
Originally Posted by fudgeass
yes, its got a cage gareth, but no, it doesnt have a bar running across the bulkhead if thats what you were thinking?
its a bolt in cage tho, not a weld in job, so i guess that would be no good either?
can you see the lugs on the sides of the pedal box? thats how it mounts, not via the studs for the cylinders like i originally thought.
surely its not 'that' difficult to make fit?
surely its not 'that' difficult to make fit?![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
dojj, due to putting a zetec turbo in and having roller barrell throttles there is no chance in hell of fitting a cossiw master cylinder in, no room at all.
so by fitting this, i will have no issues with clearance etc
Dan
When it was in my Escos it had verticle support brackets as well as the horizontal ones in you diagram
It was solid as a rock but required the drop down bracket which i didnt like
As long as you mount it with the steering column fitted & the cylinders in the box you will be fine
Steve Escos
01-10-2015 06:57 AM
deathrider666
28-09-2015 06:12 PM
Russ Payne
25-09-2015 08:29 PM
