saf 2wd cos engine loom question
Old 27-04-2006, 12:18 PM
xr4x4rs
xr4x4rs's Avatar
Default saf 2wd cos engine loom question
ok im just about to fit this engine loom into my mates sierra estate
now ive got all my wires where it normally plugs up behind the dash
only probs is i dont know what one wire does and was wondering if anyone can share some light pleae
its a brown with a red trace
the loom has to be mated up to a later loom where it normally plugs up behind the battery if that helps aswell
also i take it i will have to run a seperate wire for the oil light as the 2wd loom doesnt have one?
thanks
Old 27-04-2006, 12:27 PM
Ryan
Ryan's Avatar
think the red/brown is the oil pressure light.
not 100% though.
been a while since i've seen a standard item
Old 27-04-2006, 12:56 PM
xr4x4rs
xr4x4rs's Avatar
i carnt find the oil pressure wire in the loom, i think oil press is brown and green
ithis is what i have and what ive found out tplease tell me if im rite or wrong before i fit lol
black - ignition live
red/blue trace - live 12v
brown/white - water temp gauge
black/red trace fuel pump
green - tacho
brown/red trace - havnt a clue
Old 27-04-2006, 01:01 PM
dojj
Resident Wrestling Legend
dojj's Avatar
or possibly handbrake from what i can remember
Ryan
Ryan's Avatar
yes thats all correct.
actually i seem to remember on some saph looms there was a spare relay that was never used, still unsure what it was used for maybe its the spare realy triggered earth.
its certainly doesnt supply any of the sensors needed to run the loom.
HTH
Old 27-04-2006, 01:05 PM
xr4x4rs
xr4x4rs's Avatar
so i dont need to connect it then?
Old 27-04-2006, 07:42 PM
xr4x4rs
xr4x4rs's Avatar
btt
anyone share some light on this wire
thanks
Old 27-04-2006, 07:47 PM
bigal1978
bigal1978's Avatar
i think its for an code tester of sum sort mine is not conceted
Old 27-04-2006, 07:49 PM
bigal1978
bigal1978's Avatar
Fuel Pump = Black Red Striped (Thick Wire)
Water Temp = Brown White Striped
Oil Pressure = Brown Green Striped
ECU Diag Light = Brown Red Striped
Rev Counter = Green
Ignition Feed = Solid Black or Solid Red (Thick Wire)
Perminant Live = Red Blue Striped (Thick Wire) or 2 black wires on a 3 Door loom
Old 27-04-2006, 11:19 PM
xr4x4rs
xr4x4rs's Avatar
brilliant thanks mate
this all from where it plugs behind the dash?
as 2wd looms dont have oil lights in them or do they ?
but thanks for that info can get it running tomorrow now
big_Rad
15-09-2017 09:36 AM
Topjoe9
20-08-2015 02:38 PM
muz
16-08-2015 12:57 PM
Roosie
15-08-2015 08:09 PM
Quick Reply: saf 2wd cos engine loom question
