ABS light on Cossie
Old 24-04-2006, 06:04 PM
Mike1
Mike1's Avatar
Default ABS light on Cossie
If this comes on intermittently and the pedal/braking feels fine is it more than likely to be one of the sensors? Only started doing it yesterday - fine on journey in this morning but came on again journey home today.
Is the only way to test them without a multimeter good old trial and error or is it more likely to be the front ones?
The rear ones look to be a bit of a faff according to the workshop manual.
Any cleaning tips for the sensors?
Also anyone know where the cheapest place to buy new ones is? I was going to get a spare front and back one (if they are different front and back ) or are they handed as well? That way at least I know the sensor should be good.
Is any old whell bearing grease suitable for re-packing them or any special tips?
Done a search on this but not a lot of info
Any advice welcome
Mike
Old 24-04-2006, 06:08 PM
CosKev3
CosKev3's Avatar
Pretty sure there not handed m8,but different front to back
Your pretty lucky if you get them out without them breaking though
Easy enough to remove as long as they ain't rusted in
Think they are around the £80 mark from Frauds
Old 24-04-2006, 06:12 PM
SPADGE
SPADGE's Avatar
Check the brake fluid level and all connections to the res as these all affect the lights (diodes)
Next port of call is the connectors to the sensors on either side inner wing as these get damp and start making a bad connection.
Failing that the sensors could be fooked but i would try all of the above 1st mate
Spadge...
Old 24-04-2006, 06:20 PM
Mike1
Mike1's Avatar
Cheers for the fast responses chaps - most excellent
Brake fluid level seems fine but I shall check the sensor connectors on inner wing next ( cheers Spadge ) and to the reservoir.
It says in the manual to unclip the loom before messing with the sensors - does that apply even if the ignition is off?
Are 2nd hand sensors probably OK ( if intact ) or are they so delicate that new is the best way forward?
Thanks for all help
Old 24-04-2006, 06:26 PM
CosKev3
CosKev3's Avatar
Would think that a good second hand set would be ok m8
Try someone off here thats breaking a Saph,or one of the RS breakers,they won't rip you off
Old 24-04-2006, 06:30 PM
SPADGE
SPADGE's Avatar
Think i have some sensors somewhere
Fords want about 50+ quid each for them
Old 24-04-2006, 06:32 PM
CosKev3
CosKev3's Avatar
Priced one for old 4x4 couple years back,£72+VAT
Old 24-04-2006, 06:41 PM
SPADGE
SPADGE's Avatar
Yeah now you mention it i bought a set for the 3 door i built and they were about £240 with my old mans Ford discount deducted
Old 24-04-2006, 07:01 PM
Mike1
Mike1's Avatar
Well, the little chap has gone to sleep now so I'm off outside to check all the connections and stuff.
If that doesn't cure it, 2nd hand sensors it is!!
Old 24-04-2006, 07:59 PM
Mike1
Mike1's Avatar
Oh well, doesn't seem to be the connections - I shall get some sensors and try a wheel at a time
Old 24-04-2006, 08:03 PM
KSA-Cossie
KSA-Cossie's Avatar
Good luck m8.
Old 25-04-2006, 07:11 AM
Mike1
Mike1's Avatar
Just been reading a bit more about this problem.
If the wiring to the reservoir cap is bent, I hear this can cause the light to come on as well? ( as per Spadge's post ). When I was trying car late last night light now seems to come on with ignition and not go off at all. Pump seems to prime OK and go off ok but could it be not building enough pressure or does it run till pressure limit is achieved?
If it's a wheel sensor problem would the light come on with the ignition and not go off again OR would it only come on after the car had started moving?
What I am trying to say is that if the light comes on when the car is not moving does it point to a problem OTHER than a wheel sensor
Old 25-04-2006, 07:39 AM
richm
richm's Avatar
if the light is on at standstill it could still be a sensor, but if so it implies that the sensor circuit continuity is bad - either the sensor is damaged, wire is broken or bad connection. If the pump runs but eventually stops, it's pretty certain the pressure switch etc is working ok.
But it does sound like you have a circuit continuity problem with a sensor or reservoir connections.
Old 25-04-2006, 07:45 AM
daz1968
daz1968's Avatar
Sensors are easy to test with a meter, just un plug them and check with multimeter if open circuit they are no good, I had problems a few years ago and found that mine was a n/s front sensor using the above method, If sensors are ok then get a wiring diagram and check wiring to ecu. No use just changing sensors for the sake of it.
Old 25-04-2006, 07:54 AM
Mike1
Mike1's Avatar
OK, cheers for the info Richm - I will try cleaning all the wheel sensors for my first attempt though - going to wait till my spare ones come tomorrow just in case I do break one whilst I'm removing one.
I presume if the reservoir cap wiring is broken it's a re-wiring job back to the loom or is there a connector somewhere back in the depths so I can just buy that length - doesn't seem much spare wiring to play with to the reservoir cap as it is looped at a tight 180 degree as it is?
Old 25-04-2006, 08:13 AM
richm
richm's Avatar
If you check continuity/resistance of sensors with a meter, also check from the ECU connector, this will then include all the wiring to the sensors. Sensor wires are easy to spot in the ECU connector, they are four screened cables, green wires from memory.
yatta
21-05-2016 10:31 PM
RSmark84
13-09-2015 01:29 PM
fuzzy
04-09-2015 10:11 PM
hopper350
04-09-2015 12:53 AM
turbowag
03-09-2015 08:07 AM
Quick Reply: ABS light on Cossie
