Why wont my Renault 5 die? *Now with Video*
Old 23-04-2006, 10:29 PM
Muzz
Muzz's Avatar
Default Why wont my Renault 5 die? *Now with Video*
Ok, i have had this shitbox Renault 5 for about a year, and its MOT expired so we thought we would have a go at killing it on Saturday (Inspired by that Honda video ).
This is what we have done to it so far, bear in mind it still runs, fires up and idles .
Into the carburettor we have poured:
Washing up liquid
Water
Sawdust
Cadburys Cream Egg
Swarfega
DOT4 Clutch Fluid
Spade connectors
Assorted nuts and bolts
Into the oil filler cap we have poured:
Washing up liquid mixed with water to form a nice bubbly mixture
Another cadburys cream egg
Some more Swarfega
Lots of nuts, bolts and crimp connectors
Leaves
Freshly cut grass
Water
Various piece of metal which were carved off the bonnet.
A small amount of headlight glass.
And to top it off, we ran it on 2 cylinders for most of the time.
The fucker just wont die, i cant believe it .
So, suggestions please (other than foot to the floor and watch a rod come through the block, imaginative answers only please ).
Old 23-04-2006, 10:31 PM
BlackRSTFife
BlackRSTFife's Avatar
get a couple of 400+ horse cossies either end a couple of big lengths of chains and a pair of drivers that only know the accelerator as on and off
ESCYSCOTT
ESCYSCOTT's Avatar
Why?? You need to get out more
What a waste of 2 creme eggs
Old 23-04-2006, 10:34 PM
warleydaddy
warleydaddy's Avatar
Put aq cossie engine in it,bound to blow up at some point then!!!
Pete..
paul16v
Monte 087
paul16v's Avatar
Spray some sort of flammable spray into the carb while its running
Old 23-04-2006, 10:37 PM
Doug
Doug's Avatar
Default Re: Why wont my Renault 5 die?
Washing up liquid
Water
Sawdust
Cadburys Cream Egg
Swarfega
DOT4 Clutch Fluid
Spade connectors
Some more Swarfega
Leaves
Freshly cut grass
Water
Quality fucking wetting myself here
Old 23-04-2006, 10:41 PM
sbd16v
sbd16v's Avatar
what a waste of 2 gearboxs
Old 23-04-2006, 10:44 PM
sbd16v
sbd16v's Avatar
take the pulgs out and put some water in one clyinder
RichardC
RichardC's Avatar
a 200 shot of nos ?
Old 23-04-2006, 10:45 PM
scruffythefirst
scruffythefirst's Avatar
Drain all the oil out of it and replace with water / petrol / piss
Old 23-04-2006, 10:47 PM
marco polo
marco polo's Avatar
Hi mate
I know how to make it die very quick , get some "subaru pistons" fitted , they will melt rapidly pmsl
lenny
Old 23-04-2006, 10:50 PM
luke89
Team HOTHOT!
luke89's Avatar
put a ford badgeon it, it will brake in 5mins
Old 23-04-2006, 10:52 PM
scruffythefirst
cut the cambelt halfway through then redline it in neutral with a brick on the acc and the fan switch discconected - see if the hg goes before all the valves.
Old 23-04-2006, 10:54 PM
RichardC
RichardC's Avatar
Black and decker leaf blower supercharger
..and a 200 shot of nos
Old 23-04-2006, 10:57 PM
Terry Tibbs
Terry Tibbs's Avatar
Redline it.. won't take long.
Old 23-04-2006, 10:59 PM
Mike C
The Special One
Mike C's Avatar
Originally Posted by RichardC
a 200 shot of nos ?
gets my vote
Old 23-04-2006, 11:05 PM
MK5RST
MK5RST's Avatar
advance the timing and spray lots of easy start in through the carb at WOT, she wont last long
Old 23-04-2006, 11:07 PM
infinityMJD
infinityMJD's Avatar
liquid brasso in the oil, will kick out the end shells in no time, shouldnt take long to drop a rod after that
might have a 1.2 nova for the same treatment, but she got t&t still so might just take her out for a night of fun
Old 23-04-2006, 11:51 PM
Christian and Beccy
#1 in Spelling Club
Christian and Beccy's Avatar
I would go for a BIG downshift. 4th gear down to 1st.
Old 23-04-2006, 11:55 PM
NUTS RuS
NUTS RuS's Avatar
Its a French resistance thing
Old 24-04-2006, 01:58 AM
saff_cossie
saff_cossie's Avatar
Pete..
Has to be the best one
A tried and tested approach with a Renault 5 is to drive it and brake with no brake pads thus eventually setting fire to the wheels and the car. It was unintentional but did destroy it
Old 24-04-2006, 03:15 AM
Steve200+
Steve200+'s Avatar
Surprising... it's French, thought it'd have surrendered the moment you opened the bonnet.
Old 24-04-2006, 03:27 AM
GazzaG
GazzaG's Avatar
Don't you mean a vauxhall badge
pour brake fluid in the oil cap or petrol tank and run like fuck after starting the fucker
Old 24-04-2006, 04:06 AM
Benni
Ban[B][/B]ned
Benni's Avatar
That will work as i've done that when my friend had a vaxhaull corsa as a courtesy car. 5th to 1st at about 70 and it fucked the gearbox
Quality thread mate
Old 24-04-2006, 07:34 AM
St3V3_C
St3V3_C's Avatar
Just put a turbo somewhere close to it - should be enough to scare it. The GTT's were always blowing up weren't they?
Change the plug leads round and see if you can get it to run backwards...
Old 24-04-2006, 07:39 AM
infinityMJD
this running backwards idea sounds good, if u got an ratchet or similar high speed tool that will take a socket, should be able to start it from the crank pully!!!! starter motors wont spin the rong way cos the drive wont fire out!!!!
quality plan tho, and if she still drives means u can do 55mph backwards(think 55 is flat tap in a 5)
Old 24-04-2006, 07:41 AM
St3V3_C
St3V3_C's Avatar
Or bump start...
Old 24-04-2006, 07:45 AM
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
weld the wastegate penny shut and then hammer it. Will run very lean i expect
Old 24-04-2006, 08:02 AM
frog
0-60 in 17 seconds (eek)
frog's Avatar
I'd stick some methanol in the fuel tank and go for a 1/4 mile of glory
Muzz
Muzz's Avatar
http://smg.photobucket.com/albums/v2...enault5002.flv
This is how it was running when we were done with it Saturday afternoon . It wouldnt rev much, but its definately running
Old 24-04-2006, 11:08 AM
Christian and Beccy
#1 in Spelling Club
I can't imagine its a turbo......
Old 24-04-2006, 11:12 AM
roybacer
roybacer's Avatar
Where abouts in Farnborough u from ????
Old 24-04-2006, 11:17 AM
deleted
deleted's Avatar
Location: learnin to build a yb lump properly in dennis's garage
drain the oil and water then leave abrick on accelerator and time its death
Old 24-04-2006, 11:19 AM
big_wig_074
big_wig_074's Avatar
pour fizzy pop (proper sugary stuff!) in the header tank and degreaser (white spirit or something) in the oil,hey presto!
Old 24-04-2006, 11:29 AM
Mike C
The Special One
Mike C's Avatar
nah, it'd have blown up ages ago
Old 24-04-2006, 12:03 PM
Muzz
Muzz's Avatar
Live about 2 minutes from King George Playing Fields, South Farnborough mate. Why?
Old 24-04-2006, 12:27 PM
tracktoy
tracktoy's Avatar
valve grinding paste in the oil
Old 24-04-2006, 12:53 PM
ballin
ballin's Avatar
fpmsl - i wanna come watch!
running backwards sounds the best so far
otherwise pour some wallpaper paste in the filler cap
ballin
ballin's Avatar
ps. would love to see the oil when you drain it, please get a pic up
Quick Reply: Why wont my Renault 5 die? *Now with Video*
