98 ron fuel and cars that are mapped to run it
if a cosworth is mapped to run 98 ron fuel is ther any benifit in running 102 ron fuel if its not mapped for it will ther be any increas in preformance
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
Maybe a bit of safety factor as i'm sure i'm right in saying the higher octane fuel is more 'knock resistant' - but no power to be gained in using 102 when mapped for 98
You would probably see an increase in EGT's that you wouldnt be happy with if you increased from 98 to 102, but it depends on other qualities of the fuel not just the RON rating.
You would also see a loss in power and a loss in economy.
I'm just curious as to why there'd be a loss in power with using a higher octane fuel - i wouldn't have expected a gain particularly as the ignition would be the same etc. but i'm just struggling to get my head around a loss
Higher Ron rating (all other things being equal) means a slower movement of the flame front, which results in lower peak cylinder pressures if you dont advance the timing to utilise the slower burn.
The extra "energy" potential of the higher ron fuel would just be given off as heat not make any power.
Well based on the limited experience I have of people silly enough to use a higher CR fuel without a remap to use it properly.
Ive yet to see any car get quicker as a result of running the wrong fuel.
big_Rad
15-09-2017 09:36 AM
kosienutter
31
22-08-2015 09:55 AM
Zoggon
10-08-2015 10:39 AM
Red_bull
09-08-2015 08:34 AM
