rough price for a rebuild
my block is already a 200 block with long studs plus when i had head gasket i had a cometic groupa fitted which is reusable plus i got the ford employee card so i would get the parts cheap
A drive in drive out std rebuild would start from about £3000 (parts below), presuming it already has - greens, 3 bar, chip and stainless exhaust (if not add about £800 -£1000)
Pistons and rings
Valve guides
Bearing set (inc thrusts)
Oil pump
Full gasket set
Small end bearings
Conrod bolts
Rebore and hone block
Regrind crank
Cut and reseat valves
Light head skim
Oil and oil filter
Antifreeze
Steve
Pistons and rings
Valve guides
Oil pump
Full gasket set
Small end bearings
Conrod bolts
Regrind crank
Light head skim
Oil and oil filter
Antifreeze
Steve
yea already has t34,greens,3 bar full magnex exhaust had head skimmed bout 3000ml ago when had headgasket fitted could do myself as am motorcyle mechanic so am good with spanners and would probaly save me lot of money
Originally Posted by Stu @ M Developments
Originally Posted by abdr500
£2000 job done cant see why peopl are say 3/4 k the std compnents are good for upto 400 bhp
pistons £500 thats a 1/4 of the budget gone in one hit
re-usable gasket
Depends on what you mean by "rebuild", if its just a freshen up with some major fault fixed, such as a rehone, new rings on standard pistons and pop back together with a couple of new gaskets then it could be only a few hundred quid, but thats NOT a rebuild IMHO, to do the job properly its definately well into the thousands.
steve scott at a1, did me rebore,new pistons with cut outs,bearings,arp rod and big end and stud nut kit ,muti layer ,new t34 .48, high press oil pump,double valve springs, guides,oil seals, reface head, cam belt and tensner,and other mashine work for sensors ,2wd maifold for £2800
think it just needs ring due to my low power and cylinder leakage blowing threw crancase breather,head had skimmed when had head gaket done and fitted cometic grpa gasket and the turbo is quite new with no play rest seems ok no noises just bit of piston slap
if it has piston slap as stated it will require a rebore and new pistons + rings.
cometic gaskets are just that, not grp a which arent much good anyway. by the way they are not reusable no matter what you are told.
set of pistons £400 with rings and pins
main bearings £65
big ends £60
oil pump brand new £80
core plugs £5 set
bottom end gasket set 20
top end gasket set group a £150
skim £30
head bolts £35
lifters £80
oil filter £4
oil to run in £5
balance crank rods piston and fly wheel with clutch ect£150
re cut valves and seats £80 fit new valve guides £100 valves guides £80
clutch £250
new block £500/600
all of the above is with in £2000 only £14 over
main bearings £65
big ends £60
core plugs £5 set
skim £30
head bolts £35
lifters £80
oil filter £4
oil to run in £5
clutch £250
new block £500/600
I just rebuilt my bottom end keeping original block, so had rebore, crank grind and flywheel skim new pistons all bearings and oil pump new gaskets including cometic head gasket and alcon clutch cost me just over £1400, when I had my head done a couple of years ago cost me about £600 so I would say a minimum £2000 in parts and machining so if someone builds it for you then add another £500 minimum on top of that.
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
