now THIS is a turbo
Old 19-04-2006, 08:52 AM
  #121
Cam
Cam's Avatar
Originally Posted by keithcowie
Originally Posted by martin-reyland
Thanks for that Keith Do you have a picture of the block without the spacer fitted?
Hi Martin
Sorry i dont have a photo of the block on its own
Keith
I think I have one from my engine build at home on the PC Martin. I'll check tonight
Old 19-04-2006, 08:55 AM
  #122
Stavros
DEYTUKURJERBS
Stavros's Avatar
Fair play Keith, good pics, good info, great thread actually
I much prefer putting stuff up on here than the GTR board, and TBH i think people understand and appreciate the technicalities of it here a bit more too.
Originally Posted by Adam_BlackRS
P.S How much does the OS 3L kit cost ? ..... Don't answer that.... it'll make me cry
Lots! But when you going for 1000bhp, lots is a normal price! Keith only taking it to 9000 or so is keeping it pretty understressed, which sounds quite mad for a motor pushing 8second quarters
If you sticking with power in 3 figures and revs below 9000 then a RB30 block like mine is much easier on the wallet, infact cheaper than many built up cossie engines, which is quite nice.
Old 19-04-2006, 08:59 AM
  #123
keithcowie
keithcowie's Avatar
Yes please !
Not that bad for what you get £8000+ vat and you have your old bottom
end to sell on,OS Giken rate the kit to about 1400 bhp
Keith
Old 19-04-2006, 09:11 AM
  #124
Ish
Ish's Avatar
awesome
Old 19-04-2006, 09:24 AM
  #125
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
Hi Martin
Keith
no problem... just curious
Old 19-04-2006, 09:50 AM
  #126
keithcowie
keithcowie's Avatar
Hi Martin
You need to get one of these carbon props on your car only 5kg
Old 19-04-2006, 09:57 AM
  #127
capri-rs
capri-rs's Avatar
that is just awesome
Old 19-04-2006, 12:17 PM
  #128
Philip
Philip's Avatar
OS Giken made the change to the
spacer plate a while ago
Keith,
Do you know why? You would imagine it would be stronger with the closed deck of the old design.
Phil
Old 19-04-2006, 12:28 PM
  #129
keithcowie
keithcowie's Avatar
Keith,
Phil
Hi Phil
When you run big power on a RB26 skyline engine the weak part is the cylinder
walls the OSG kit has 10mm steel liners that are very strong and the crank also
has much wider bigend journals they have about 10mm more surface area over std.
the rev limit on this 3L engine is still 9000 revs.
Keith
Old 19-04-2006, 12:31 PM
  #130
Philip
Philip's Avatar
Keith,
Phil
Hi Phil
Keith
The old-style Giken engine in all the promo pics has the same thick liners, so why change the spacer plate to the open design? Problems with expansion or something?
Phil
Old 19-04-2006, 12:37 PM
  #131
keithcowie
keithcowie's Avatar
Phil
Hi Phil
I have no idea i think the change was made a long time ago
i will try and find out for you.
Keith
Old 19-04-2006, 12:50 PM
  #132
EvilFranky
EvilFranky's Avatar
I asked about fitting a carbon prop to a cossie a while back and got laughed at
Summit about loseing torque???
Old 19-04-2006, 12:51 PM
  #133
Cossiebros
Cossiebros's Avatar
Excellent topic
Looks like a good piece of engineering
Old 19-04-2006, 12:52 PM
  #134
TM
TM's Avatar
Who said that
Old 19-04-2006, 01:07 PM
  #135
Stavros
DEYTUKURJERBS
Stavros's Avatar
Who said that
An eejit surely, there no flex, shouldnt make a difference in that respect.
Old 19-04-2006, 01:20 PM
  #136
bcracknell
bcracknell's Avatar
Hi Martin
I love the fact that the prop is obvously designed to handle a lot of power but it still says fragile handle with care on the box!
Old 19-04-2006, 01:27 PM
  #137
Cam
Cam's Avatar
Hi Martin
If the tube is damaged in transit its scrap. Its ultra strong in certain plains but not as forgiving to side impacts
Old 19-04-2006, 01:40 PM
  #138
Philip
Philip's Avatar
On the upside, it won't tear you to pieces or pole-vault you if it breaks on the car ...
Phil
Old 19-04-2006, 02:18 PM
  #139
Kev.H
Kev.H's Avatar
Old 19-04-2006, 03:28 PM
  #140
DazS1Turbo
DazS1Turbo's Avatar
Awsome Thread and awsome bits of kit
Very interesting
Old 19-04-2006, 04:15 PM
  #141
keithcowie
keithcowie's Avatar
Here are a few photos of the car
Old 19-04-2006, 04:21 PM
  #142
aduz
aduz's Avatar
we want 8's..we want 8's
Old 19-04-2006, 04:30 PM
  #143
COMEDY DAN
No1 Blower.
COMEDY DAN's Avatar
Thats going to need about 11 dumpvalves.
Old 20-04-2006, 03:33 PM
  #144
keithcowie
keithcowie's Avatar
Hi aduz
SO DO I
Keith
Old 20-04-2006, 04:43 PM
  #146
big_wig_074
big_wig_074's Avatar
did someone say big turbo?
http://videos.streetfire.net/video/9...272D9A953D.htm
Old 23-04-2006, 08:23 AM
  #147
dumped
dumped's Avatar
Muhahahaha Mental spec!
My turbo is only a didly 125lb job but more importantly i never plan to run it anywhere near that so no point in comparing anything! Turbo system is way over 125lbs though
Look forward to seeing this wind up on the strip
Old 23-04-2006, 09:07 AM
  #148
Martin-Hadland
Hi Martin
Have already enquired about one and am just about to take the plunge..
Old 28-04-2006, 08:54 AM
  #149
EvilFranky
EvilFranky's Avatar
Well I always thought a carbon prop would be a good idea especially on a Cosworth, to help reduce transmission power losses.
With them being considerably lighter weight i'd have thought a few bhp may have been saved?
Old 04-05-2006, 09:33 AM
  #150
BIG-BHP RACING
BIG-BHP RACING's Avatar
105mm throttle body that will be fitted to our own plenum design
Keith your car look's realy good and that engine
But you need to check the throttlebody they are not the best
Accufab TB have big problems with airleak. They leak air between the trottle shaft and the tb house, and that's no good. So check that.
Anders.
JK12
33
26-04-2021 12:09 PM
RSBryden
06-09-2015 08:39 PM
cozzzzy power
04-09-2015 08:14 AM
turbowag
03-09-2015 08:07 AM
Jerry Ryan
02-09-2015 08:02 PM
Quick Reply: now THIS is a turbo
