3 door car loom splicing with 4x4 saph engine loom
Old 16-04-2006 | 12:50 PM
cossiecrew's Avatar
cossiecrew
Default 3 door car loom splicing with 4x4 saph engine loom
Old 16-04-2006 | 12:59 PM
rsnissan's Avatar
rsnissan
got loads of pics from when i had the engine out so let me know if you need any others, different angles etc.
They are all high res so i can zoom more if you need
Old 16-04-2006 | 01:03 PM
Ginge !'s Avatar
Ginge !
just finding my feet
fucking buftys the pair of ya
andy you coming central day and the piss up btw ,,,,,, as i need a lift
Old 16-04-2006 | 01:20 PM
cossiecrew's Avatar
cossiecrew
cheers andy what im trying to find out is where the engine loom meets the car loom got any pics ?
Old 16-04-2006 | 01:23 PM
Ginge !'s Avatar
Ginge !
it meets behind the dash dont it and joins the live, neg and the water temot sensor inn the ecu ?????
a 2wd cossie does anyway
Old 16-04-2006 | 01:30 PM
cossiecrew's Avatar
cossiecrew
il take a look at the 4wd loom meets in the engine bay back in 10
Old 16-04-2006 | 01:32 PM
rsnissan's Avatar
rsnissan
Ginge i still aint decided what i am doing yet can sort it this week though
Ginge is correct it meats the loom wehre the relays are (ie behind dash)
p.s i aint a bufty
Old 16-04-2006 | 01:36 PM
cossiecrew's Avatar
cossiecrew
right think ive found it but theres 2 plugs some of the wires are the same though it looks promising if i took pics would anyone tell me if im correct and what wire does what and where to connect them
Old 16-04-2006 | 01:42 PM
rsnissan's Avatar
rsnissan
get some pics up so i can see what the hell your babling about
I did mine over a year ago but IIRC it was all simple enough and fairly straight forward (the looms shoud be the same other than the TPS wiring and maybe some other bits for a knock sensor etc for the 4x4's that had them)
the only bits i had and dramas with was the fuel and ignition relay wires where they were spliced for my alarm and imobiliser
Old 16-04-2006 | 01:50 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
2wd engine loom joins car loom via a single plug behind abs/ecu above the glove box inside the car.
4wd engine loom joins car loom in the engine bay with 2/3 multi plugs at the back of the cam cover area.
Old 16-04-2006 | 01:53 PM
cossiecrew's Avatar
cossiecrew
right here goes
SAPH 4X4 ENGINE LOOM
1X6 PIN CONNECTOR
CONTAINING
1XTHICK BLACK/RED
1XTHICK RED/BLUE
1XTHIN BROWN/WHITE
1XTHIN BROWN/GREEN
1XTHIN GREEN
1XTHIN BLACK
3DOOR LOOM
1X4 PIN PLUG
CONTAINING
1XTHICK BLACK/RED
1XTHIN BROWN/WHITE
1XTHIN GREEN
1XTHIN BLACK
1X2 PIN PLUG
CONTAINING
1XTHIN RED
1XTHIN BROWN/GREEN
now the only differences is 3door has a thick red/blue and the saph has a thin red anyone help me out here and are all the other matching wires a simple join up
Old 16-04-2006 | 02:11 PM
cossiecrew's Avatar
cossiecrew
dont go quite on me now
Old 16-04-2006 | 02:13 PM
Staffi's Avatar
Staffi
Get yourself a NMS Pectel Loom
Old 16-04-2006 | 02:22 PM
cossiecrew's Avatar
cossiecrew
thats zero help to me right now any excuse to post a pic though innit pete i could ring karl but wouldnt want to bother him being easter and sunday
Old 16-04-2006 | 02:24 PM
Staffi's Avatar
Staffi
Iknow its no use, thats why i did it
Old 16-04-2006 | 02:25 PM
Ginge !'s Avatar
Ginge !
whats a NMS pectel loom
is that just a engine loom made by NMS or has it been made by pectel for NMS
Old 16-04-2006 | 03:21 PM
cossiecrew's Avatar
cossiecrew
i would of thought it was one of dingys looms might be wrong though anyway back to topic who can help me out
Old 16-04-2006 | 04:08 PM
cossiecrew's Avatar
cossiecrew
right here goes
1X6 PIN CONNECTOR
CONTAINING
1XTHICK BLACK/RED
1XTHICK RED/BLUE
1XTHIN BROWN/WHITE
1XTHIN BROWN/GREEN
1XTHIN GREEN
1XTHIN BLACK
3DOOR LOOM
1X4 PIN PLUG
CONTAINING
1XTHICK BLACK/RED
1XTHIN BROWN/WHITE
1XTHIN GREEN
1XTHIN BLACK
1X2 PIN PLUG
CONTAINING
1XTHIN RED
1XTHIN BROWN/GREEN
wheres all the experts
Old 16-04-2006 | 04:35 PM
Ryan's Avatar
Ryan
yes its a dingy loom, and nothing to do with pectel
Old 16-04-2006 | 04:40 PM
Staffi's Avatar
Staffi
So Karl has told me aload of bollocks then is that what your saying
Old 16-04-2006 | 04:41 PM
Ryan's Avatar
Ryan
Im sure he told u nothing of the sort.
Its a loom made by Dingy for NMS
Old 16-04-2006 | 04:45 PM
Staffi's Avatar
Staffi
So why on my receipt did he put pectel loom?
Old 16-04-2006 | 04:53 PM
cossiecrew's Avatar
cossiecrew
yo thread stealers help me out who gives a flock about petes loom HELP MEEEEEEEEEEE
Old 16-04-2006 | 04:54 PM
cossiecrew's Avatar
cossiecrew
right here goes
1X6 PIN CONNECTOR
CONTAINING
1XTHICK BLACK/RED
1XTHICK RED/BLUE
1XTHIN BROWN/WHITE
1XTHIN BROWN/GREEN
1XTHIN GREEN
1XTHIN BLACK
3DOOR LOOM
1X4 PIN PLUG
CONTAINING
1XTHICK BLACK/RED
1XTHIN BROWN/WHITE
1XTHIN GREEN
1XTHIN BLACK
1X2 PIN PLUG
CONTAINING
1XTHIN RED
1XTHIN BROWN/GREEN
Old 16-04-2006 | 04:58 PM
Ryan's Avatar
Ryan
1X6 PIN CONNECTOR
CONTAINING
1XTHICK BLACK/RED = Fuel Pump Trigger
1XTHICK RED/BLUE = Permant Live
1XTHIN BROWN/WHITE = Water Temp Gauge
1XTHIN BROWN/GREEN = Not 100% on that one been a while since i've looked at a 4x4 loom (think it may be Oil Pressure Warning Light)
1XTHIN GREEN = Rev Counter
1XTHIN BLACK = Ignition Live
3DOOR LOOM
1X4 PIN PLUG
CONTAINING
1X2 PIN PLUG
CONTAINING
1XTHIN RED = Igniotion Live i think
1XTHIN BROWN/GREEN = Fault Finding Display (Pin 12 on ECU)
Old 16-04-2006 | 05:07 PM
cossiecrew's Avatar
cossiecrew
so 4 of the 6 are just a join up job but what do i do with the remaining 4 wires then
Old 16-04-2006 | 05:14 PM
Ryan's Avatar
Ryan
Well heres the problem.
The 3dr Loom uses a permanant live direct off the battery, the 4x4 loom uses a permanant live that comes through the main car loom, so you obviously wont have this on your loom, so you will need to sort that out.
Other than that, the only other wires the 3dr needs is:
Ignition Live (Thick Black)
Fuel Pump Trigger (Thick Black\Red)
Rev Counter (Thin Green)
Water Temp (Think Brown\White)
The final problem is the 3dr has a ECU check light on the centre console, this is controlled by pin 12 on the ECU, the 4x4 wont have this.
Hope this helps.
Old 16-04-2006 | 05:23 PM
cossiecrew's Avatar
cossiecrew
does it need the ecu check light ? as im using the 4x4 ecu anyway
Old 16-04-2006 | 05:24 PM
Ryan's Avatar
Ryan
no it doesnt need it to run.
Old 16-04-2006 | 05:37 PM
Jay,'s Avatar
Jay,
Sponsor
rayn does the german 3 door diagram same as english?
Old 16-04-2006 | 05:40 PM
cossiecrew's Avatar
cossiecrew
the diagram im looking at says the brown/green is oil pressure and if your saying thats what it is on the saph do these just connect then were veiwing the german diagrams
Old 16-04-2006 | 05:52 PM
Ryan's Avatar
Ryan
jaycos, yes there both the same
cossiecrew, thats correct, but the oil pressure doesnt go to the ECU, so its deemed usless when used on a 3dr
Old 16-04-2006 | 06:06 PM
cossiecrew's Avatar
cossiecrew
give me a dummy guide dont tell me what they all are just tell me what to connect to what and what to do
Old 16-04-2006 | 06:11 PM
Ryan's Avatar
Ryan
Right:
3dr Main Car Loom to Saph ECU Loom
Thick Black\Red to Thick Black\Red
Thick Brown\White to Thin Brown\White
Thin Green to Thin Green
Thick Black to Thick Black
Thin Brown\Green on the Saph ECU loom is no longer used
Thick Red\Blue on the Saph Loom needs to be connected direct to the battery with an inline fuse. (15Amp)
The Brown\Green from the 3dr Main car loom is no longer needed either.
Think thats it.
Old 16-04-2006 | 06:13 PM
cossiecrew's Avatar
cossiecrew
1 thing is there thin blacks not thick
Old 16-04-2006 | 06:18 PM
Jay,'s Avatar
Jay,
Sponsor
check it see if it ign live mark
Old 16-04-2006 | 06:21 PM
cossiecrew's Avatar
cossiecrew
right mucho respect to ryan and jay for your help will check them tommorow as its getting chilly outhere
Ryan's Avatar
Ryan
or the 3dr loom cossiecrew?
will be an ignition live.
Old 16-04-2006 | 06:22 PM
Jay,'s Avatar
Jay,
Sponsor
anadin ryan pmsl
j.hammond1
30
31-10-2021 05:28 PM
big_Rad
15-09-2017 09:36 AM
kosienutter
31
22-08-2015 09:55 AM
jimmy oldskool
Ford Focus (All Models)
04-08-2015 06:54 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: 3 door car loom splicing with 4x4 saph engine loom
