custom bracket fabricating, where from, how hard?
Old 10-04-2006, 09:46 PM
Mr C
Mr C's Avatar
Default custom bracket fabricating, where from, how hard?
I want this built in 5mm steel to mount my diff to my rally car floor. How hard is it to weld something like this, seeing as Ive done the hard work, someone just has to copy my template.
If I dont get a resonable quote soon I will be welding it myself
Where can I get 5mm plate from and a Mig welder too?
Old 10-04-2006, 09:47 PM
cossiecrew
cossiecrew's Avatar
lee@fusion
Old 10-04-2006, 09:57 PM
THEYGOTMETOO
CUNT!
THEYGOTMETOO's Avatar
Location: BLUE PILL or RED PILL ... All I offer is the truth, nothing more, nothing less. You choose.
It's extremely easy to do - as long as you have the right equipment! For metal just look under metal stockholders in the Yellow Pages, you can hire welders too.
I remember seeing a welded mild solid diff hanger on eBay not that long ago.. have to admit it look really nasty though
I'm just finishing the CAD work on a billet rear diff hanger at the moment which looks something like:
Old 11-04-2006, 11:27 AM
RichardPON
RichardPON's Avatar
Mark - speak to Brom.
He did my original one, which if I still have it, yuo can have (although my diff was completely different to yours.
He should be able to knock something up for good money, especially with a little model like that - very neat
Old 11-04-2006, 01:56 PM
GARETH T
GARETH T's Avatar
anyone should be able to make that
i cant believe you took the time to make it in wood,
Old 11-04-2006, 03:25 PM
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
Danny B, In Northants
Old 13-04-2006, 07:38 PM
Mr C
Mr C's Avatar
I got a quote from Zoo, he needed the car for 2days to do that and Gearbox mount, which I cant do yet
I have had a few offers on here now to fabricate the bracket thanks everybody for your help, there are a couple of concerns though;
1, the use of just 2 stud and nuts isnt ideal and further dowls were apparenty used to locate the original diffs in the chassis?? there are holes for this on the shell
Also
2, the strenghthening supports may not be needed, anybody confirm or deny this? It will be made in 6mm Steel, will a 90deg bracket be sufficient strong without?
RichardPON, yeah that bracket would be most helpful if it never went with the 10"diff, if Brom thinks it was fine just bolting a flat plate across, Im sure it will be strong enough as its triangulated across the solid beam mounts and diff doesnt sag much without a bracket at all
Old 13-04-2006, 07:44 PM
Mr C
Mr C's Avatar
I had to build it as the car is stored a couple of mile away with no running gear on, no diff to take measurements from, and an unusual/non standard mount, wasnt a bad guess from what reference measurements I had from the diff at home and beam already on the rally car. 5mm out on the mountin face of the diff, so elongating the M12 mounting holes will do the job
And I had to be sure it fitted, no excuses no blame... unless of course the finished item wont fit when its fabricated and fitted on the diff, in which case I will erase this post
Old 13-04-2006, 07:52 PM
Zetec Andy
Zetec Andy's Avatar
Lee@fusion, details are in my siggy
Old 25-04-2006, 01:46 AM
CozzyBrom
CozzyBrom's Avatar
u neva told me you had a patten to work from thats easy to make £50
Old 25-04-2006, 08:47 AM
RichardPON
RichardPON's Avatar
There's your answer mate
Brom - how you doing fella? Hope everything's better
SMILER258
28-09-2015 09:04 AM
Quick Reply: custom bracket fabricating, where from, how hard?
