Can you start engine and lock doors from the outside?
as title? no remote start by the way, just starting the engine and then locking the doors from the outside with another key? Is that possible, ive never tried it
apparently on some cars there is some ways of doing it..
if you create a fuse between some of the wiring in the rear lights cant remember which ones.. you can unlock it and start the ignition allowing you to bump it off...
Originally Posted by teamfatboy
why???
as far as i no this is a myth, You see aimilar in gone in 60 with the fog lamp being fused, the idea is that the alarm is on the same cicuite as the lamp so bridging it will blow the alarm, problem is if the lamp is off where is the current to blow the fuse going to come from???
as for the unlocking by messing with the reaer lights, could be related to getting to the loom behind and tricking the car into thinking the boot lid is opened buy the key, there by trigering the central locking, this however would mean ripping out the cluster
So to sum up, just another urban legend!!!
why???
no reason why you couldnt fit an external start stop system, some alarms come with it allready! you can start the car from the living room, watch tv while she hots up, then out ya go and unlock with another button and away you go!!! that or find someone a bit handy on wiring and get a second ignition fitted somewhere! key through the grill or in the boot lid or some thing, if ppl can fit a cos block in a festa an ignition swith should be no biggy
I used to use the clifford concept 5 billion alrm that was on my old crx vtec, i payed £600 for the wreck of the car and the lad had just spent £680 on the bastard alarm the knob.
Proper functional for cold winter mornings, set the heaters to full bore the night before, then just wake up press a button, get ready and jump in your nice warm car and go to work
Yes you can, I used to do it all the time with my old S2 and that had a cat1 alarm fitted, just lock the doors manually (with the key) and dont press the fob.
Done it also with both my mondeos and also my sprinter van
just finding my feet
shows what you know mate
the way it works is by shorting the indicator with a bit of foil when you go to enter the car when it triggers the alarm it then makes the indicators flash and when that happens the short blows the fuse
btw that was the old 90's way of nicking cars,,,,,,,,,, since then the alarm companys use a perm live feed not feed from the indicator stalks and have there own fuse so this no longer happens,,,,,,,,,,,, but it did happen and it happened alot too !!!!!
Originally Posted by 89XR2
Originally Posted by RichardC
would be just my luck to leave the fooker in gear
well apart from xrt-si's one,,,,,,,,,, as that remote melts a engine or if not its dumoing its oil all over someones drive
unless im using it then when i use remote start it melts a fuse
If it's for the car in your sig then yes you can do it cause to activate the alarm you have to keep the key turned in the lock for a few seconds till the indicators flash
Team HOTHOT!
I do this with my poxhall Omega, altho on them you can remove the keys from the ignition, once the car is running and then walk away, but if you touch the brake or clutch without the key in, the engine shuts down
haha...
In my vectra you can start it... and yank the key out of the ignition with it still running.... i guess i could lock it.... but its only on my drive way
But then part of me hopes someone will nick it
JoeyBoyden
04-01-2024 02:36 PM
rog
04-09-2015 12:10 PM
track.focus'd
12-08-2015 05:53 PM
Red_bull
09-08-2015 08:34 AM
