so who has a 180-200 bhp erst what mods got u that then
Apart from the obvious (Chip, Filter, Exhaust), you will need a good Intercooler and ideally a Stage 3 Turbo to get to 200. It can be done on a Standard Turbo, but needs to be set up well. Possibly a cam too.
i've got a 1.8 zvh,which has piper 285t2 cam,bajyoo chip,collins actuator.piper cross induction kit,amber performace stg 1 hybrid! only had it rolling roaded once which was before the cam and hybrid were fitted! ity made 194@fly and 165@wheels with 13psi of boost! Just gotten it on the road again so will be getting it set up in the next few week's! hopefully getting intercooler for it aswell! hoping for about 230!
Irritating c........
Can anyone tell me what mine might be?
Mods are; chip, filter, zorst, kent cam, hybrid turbo with -31 and stg2 head. Decent plugs and leads on it, and boost is set to 12psi on std intercooler....
The previous owner reckoned on 190-195, but I thought dreeeeeeeamer and would doubt if it is much higher than 170bhp tops...
That all?
Was always led to belive that a std RST with jsut a chip, filter and zorst running 14psi wuold make about 165-170, so adding my stg2 head and cam, and the hybrid turbo I was guessing it would make 170bhp????
my series one which i had set up at jamsport on wednesday last week made 176bhp and 174lbft at 14psi. The only things it has had done is two years rest while I have been sorting out the body oh and it does have a piper cam I think.
Regards
Trev
Regards
Trev
GRS Intercooler
Standard Turbo
Piper 285T2
Low Comp
Unknown Head
Stainless Exhaust
K+N Induction Kit
Chip
18psi
NMS Setup
Unsure on true figure but believed to be around the 200bhp mark
Scott
Standard Turbo
Piper 285T2
Low Comp
Unknown Head
Stainless Exhaust
K+N Induction Kit
Chip
18psi
NMS Setup
Scott
i think people are getting confused between @ wheels and @ flywheel
my old s2 with evo 7 cooler, 15psi, k&n, scorpion exhaust (old type, not restricted), nms chip and setup and it made 208bhp (flywheel obviously).
AND the clutch was slipping.
Originally Posted by Thrush
That all?
170-175bhp easily
every car is different, i've had turbo's with the same set up, ranging from 174bhp-
191bhp.
as a ballpark figure, a non chipped S1/S2 with pipe & filter running 10 psi should
make 150ish bhp, chipped with 14 psi it should make 180ish bhp, then with a
uprated cam & cooler & 17 psi it should be pushing the 200bhp mark.
after this reliable power starts getting expensive.
another factor is where you get your car tuned, this can have a large differance
on different rollers.
191bhp.
james raby! my car made 194 with standard cam and turbo@13 psi! Since then it has had tha cam and hybrid fitted! Soon an intercooler! it is a low comp zvh! i forgot to post this! according to ian howell my car should make 230-240 with this spec!
LOL my car is about 160 Bhp at the moment
7.6:1 accralite pistons, new rods, balanced bottom end, Chip, filtter, exhaust, Grs stage 3 turbo, 5th injector, standard cam and head and a monsterous 12 Psi of boost
Im waiting for the rest of the bits to be done (ie bodywork) before i finally get a stage 3 head and put my 285t cam in it.
After that i should be running arround 24Psi and getting arround 240Bhp
Queer hairdresser
Can see where the 230 will come from now
my mates is running just above 150bhp at the fly with a scorpion , filter and upped boost, but is a very well maintained engine!!
just thought it was quite good after reading these claims on this thread.
is that about right do you reckon??
When mine was 165bhp it had: Magnex, Chip (15psi), filter on 105k old engine.
To go to the next level i was told I would need a bigger intercooler and a Stage 1 Hybrid would see it 185-195 without too much trouble.
But I decided to go about 5 stages further
It'l go well, just won't be as safe without all the other gear on top i.e intercooler, bigger turbo, cam - this all helps just doesn't get taken into account most times
It's like with modifying engines, you have to upgrade a million other thins too on the car, it just won't work modding one thing and not bothering about another...
all depends on how good your motor is to start, ive got a print from many years ago with just 15 psi and fueling done plus chip and roling roaded for 181 @ fly
by a good tunner on this board..
andy
andy
Mc5506
05-10-2015 10:57 PM
