Best place for a fitting kit for gray's?????
I have just got my new car tested 2day .and ill have the tax 2moro .but before i kill it i have got the car booked in to get setup at carwise on teusday.......but now im thinking if i am going to get it setup i may aswell put my gray's in and get a new chip while i am there but need a fitting kit so were is the best place to got 1 before teusday??????......then playtime
what sort of power im i looking at with grays?????
spec:
200block
low comp
greens
3bar
t34
rs500 cooler
not sure what cams
l&b bottom end
wrc head gasket
and so on
AND 2WD (SIDEWAYS)
spec:
200block
low comp
greens
3bar
t34
rs500 cooler
not sure what cams
l&b bottom end
wrc head gasket
and so on
AND 2WD (SIDEWAYS)
Ill tell you on tuesday night after setup..........do you think if i order off stu ill have the fitting kit on monday????? seens a bit short notice...never thought of asking carwise if they stock them ill have to ring 2mora.......hopeing for 420bhp ish or you think that dreaming abit...just need to knack me mate in his mk2 golf 20v turbo
I'm fairly sure Stu only supplies the fitting kits with injectors. IF so, you could try PJ or Woodford?
Have you had any headwork done? (RE: your spec' above)
I disagree with no fitting kit - you may not want to run the pintle caps as they come, but the o rings etc are fairly important for fitting to the fuel rail/inlet safely
...my fitting kit is 2 o rings on the bottom and 2 o rings on the top...just get a washer and drill to make a tight fit on the top obviously the right size to fit in the rail!...Put the washer on the top first then the o-rings(stops o rings slipping down)
This works and is very cheap and will NOT leak once bolted up...i know my Escos runs the Bosch Mans fitting kit
borboyous
22-08-2015 11:17 AM
