s2 brakes ???????????????
right can someone give me some advise iv been doing some brakes on a mates s2 iv ripped all the abs (scs) shit off and re piped it front to rear and fitted cozzy rear brakes and some willwood 4 pot fronts iv done this by feeding the front brakes from the rear outlet on the master cylinder to tee peace then to each wheel and and rear from the front outlet on the master cylinder to rear threw a byass valve to a tee peace to to each wheel but cant get a good peddle there is no air in the system what so ever iv even tried another master cylinder and its still the same iv checked that the rear calipers are adjusted up ok and still a shit peddle any ideas what it could be before i go and burn the thing cheers! ant
did you bleed the rear calipers with the bleed nipple at the highest point? If not you need to undo the caliper and slide it round the disc until it is then bleed it...
Also did you bleed everything with the car jacked up or on the floor?
If it was jacked up the rear load compensators will give the brakes a shit feel
oh ok you didn't say you'd ripped them off...
not being funny but did you bleed them with the handbrake off? Also with the bleed nipples on the rear at the highest point?
Originally Posted by NUTS RuS
What happens if you swap the front / rear pipework on the m/c ?
Are you still running the servo ?
Had very similar problems when I fitted big brakes up front and rear discs...Are you using a pressure bleeding kit? I found the eezibleed kit worked well in the end..
