MTX75 and LSD
Old 02-04-2006 | 07:58 PM
Avinitlarge's Avatar
Avinitlarge
Default MTX75 and LSD
Do any Std MTX75 boxes have an LSD fitted?? I cant think of any but maybe someone knows different
Old 02-04-2006 | 09:23 PM
zippyobrien's Avatar
zippyobrien
i was under the impression its easyer to carry out a three shaft or equal shaft conversion, meaning u dont need lsd
Old 02-04-2006 | 09:24 PM
Graceland's Avatar
Graceland
Team HOTHOT!
4x4 MT75 from an XR4x4 or 4x4 cossie has one fitted in the transfer case as standard
Old 02-04-2006 | 09:25 PM
Graceland's Avatar
Graceland
Team HOTHOT!
ooops, misread - didn't see the mtX75 part
for me
Old 02-04-2006 | 09:37 PM
MK5RST's Avatar
MK5RST
which mtx75 we talking about? mk5 rs2k or focus hydraulic clutch jobbie?
Old 03-04-2006 | 12:05 PM
Avinitlarge
Ah right, As in what I already have fitted? Passenger side shaft straight to the hub and drivers side has a shaft bolted to the block and another shaft from that to the hub.
I always wondered why my shafts were like this. Still, It cant work that good, Cant get any traction.
Old 03-04-2006 | 12:30 PM
the saint's Avatar
the saint
I know of a lsd in a mtx75 box (mk5 rs2k) but it aint standard
I want one but funds are not there
Old 03-04-2006 | 06:29 PM
Avinitlarge
I know the feeling, My engine rebuild is costing quite a bit more than i expected, Gearbox being uprated is looking pretty bleak at the mo
Old 06-04-2006 | 02:53 PM
James's Avatar
James
think quaiffe do one off the shelf for about Ł560?
Old 06-04-2006 | 03:13 PM
CarismaDave's Avatar
CarismaDave
Yup, get an ATB from Quaife, around Ł500+
Dave
Old 06-04-2006 | 03:16 PM
BlueSmoke's Avatar
BlueSmoke
PassionFord's crazy fool!
I've got an MTX75 box in Leeds that you can have if you want one to butcher one mate.
Old 06-04-2006 | 03:17 PM
D19 STE's Avatar
D19 STE
Whats that
Old 06-04-2006 | 03:24 PM
James's Avatar
James
The thinking is equal length driveshafts help to minimise torque steer as the torque is transmitted to the wheels in equal lengths thus helping reducing the common fwd fault of it steering usually left on acceleration.
however it doesn't always work aswell as the theory as says it should.
LSD on the other hand is a bit different, one wheel will spin, this will lock the viscous diff and lock the plates inside together so you then have both wheels spinning, but usually you have the inside wheel spinnning on corners so the diff locks giving you much better tractio to get out of corners, and off the line.
Old 06-04-2006 | 03:26 PM
D19 STE's Avatar
D19 STE
Old 06-04-2006 | 04:16 PM
white cab's Avatar
white cab
the atb diff is an awesome bit of kit a friend of mine was running one in a s2 with very high power could nail it in third with very little torque steer or wheel spinnig. but 300bhp 1st and 2nd gear its going to be a handfull in a front wheel drive car. the thing is with the quaife is that if any cv joints go you loose all drive not like the gripper diff which will still drive i belive
mk1turboestate
02-12-2015 08:31 PM
massivewangers
30
01-10-2015 07:40 PM
dalmarshall
Ford Classics & Vintage
01-10-2015 06:46 PM
cossirob
16-09-2015 07:39 PM
fordfiestamk3
11-09-2015 12:52 PM
Quick Reply: MTX75 and LSD
