how do i remove a spigot bearing on a cossie ???
just finding my feet
help, its fooked and thats why the engine aint going in,,,,,,,,,,,, the engines in the air so a resonably quick answer would be more than appriciated
I take it you wont have a small puller to hand ?
So the easiest way is to get your newspaper off the coffee table and shred it in to small pieces then soak it in a bowl of water then insert the wet paper in to the hole in the end of the crank shaft so its full then with a drift and hammer compress it whilst you keep adding more wet paper eventually this will push the bearing out ! .
Hope that does the job .
Regards Doug .
Regards Doug .
Testing the future
or use a very heavy grease, plasticine, or blu tak to stuff in the hole as doug describes. the best tool to use is then an old gearbox input shaft, as it fits the hole properly. alternatively, use a well fitting drift as doug says
engine was taken to work and we used a slide hammer with the end that splays out and it litterally poped out
ive since ordered one for the next time i need to do it
Si B
12-09-2015 06:49 AM
grishenko45
09-09-2015 12:58 PM
